Old 06-25-2009, 09:14 PM   #1
greenhorn
Question carburetor
the problem is
where the gas line atteaches to the carburetor
the threads are striped where the big nut holds the filter in
i still have 1/2 inch if thread not used
can i get that nut longer
or do i have to replace the carb or bowl
i found the nut longer except the flared end was bigger and couldn't find a reducer
68 c-10
250 rochester carb
thank's everone
greenhorn
mike
greenhorn is offline   Reply With Quote
Old 06-26-2009, 06:42 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: carburetor
greenhorn,I had the same problem,on a 250 monojet.I couldn't even get a nut thru the locl APS.I happened by the Speed shop about 6 blocks from work and decided to stop in and see if they had one.They had a whole wall full.Turned out that a new one solved my problem.I guess the new threads were in better shape.I also think they make a self tapping type that is just slightly larger to solve this problem.Carb parts are getting rare at the APS but the drag racers still use them so the speed shop may be a better source for parts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-26-2009, 09:06 AM   #3
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: carburetor
Make sure and use gad approved teflon thread tape!
prostreetC-10 is offline   Reply With Quote
