Old 06-26-2009, 08:42 AM   #1
bddcustoms
bddcustoms's Avatar
RUST - Is this cab too far gone?
Fellas:
I want to determine if the rust repair on my '69 is (1) possible, and (2) worth it. My cab has the standard problems (rockers, corners, foot wells), but the after market supports those repairs easy enough. What I'm seeking opinion on right now are the common, but challenging repairs to the cowl area, the windshield pillars, and the cowl vents -- are they possible to repair. As for are the repairs "worth it" to me that means that while it might be less expensive to replace the whole cab, the repair work isn't so expensive as to be ridiculous (I have some sentimental attachment to this truck).
If you have experience, or advice I'd take both. And if you know of a good body man in the Baltimore, MD/Washington, DC/Northern Virginia areas that is familiar with our vintage trucks, let me have that to. Here are some pics:
War GM
PS RIP MJ
broke d!@k dog Garage
1969 C20 - Project: "Big Sexy" [http://67-72chevytrucks.com/vboard/s...d.php?t=454894]
2003 'Burban - [Big Pop's daily driver]
1969 350/350 Stingray - [as soon as the economy turns...]
1939 Chevy Roadster Pick Up - Project: "Pre-School" (searching now)
bddcustoms is offline   Reply With Quote
Old 06-26-2009, 09:29 AM   #2
BigCarl
Re: RUST - Is this cab too far gone?
Depends on your welding skills. You will have to remove the windshield to address the one under the windshield. I will tell you though, if that is all the rust on that cab and I was closer I would come take it off your hands.
BigCarl is offline   Reply With Quote
Old 06-26-2009, 09:33 AM   #3
jerry moss
Born Psycho
jerry moss's Avatar
out here it would be scrap but if you have the skills to replace all the bad areas i'd like to see it after you finish. the cab on my 72 cheyenne is nowhere near that bad and i'm scrapping it.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-26-2009, 10:12 AM   #4
craig24671
craig24671's Avatar
I would repair that if you have the skills does'nt look that bad to me
Spanky
craig24671 is offline   Reply With Quote
Old 06-26-2009, 10:25 AM   #5
71 super
71 super's Avatar
That is all fixable, instead of removing windshield, cut access hole large enough to fix the issue through the solid area in the cowl, fx the problems with new metal and replace the section you cut out. The cowl cover will cover the cut but if you finish the welds properly no one will ever know your made the repair.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-26-2009, 12:40 PM   #6
danw210
69 K20
I would look for another cab but thats just me. I have minimal welding skills though. I would bet that you have some bad rust issues under that windshield too.
danw210 is offline   Reply With Quote
Old 06-26-2009, 04:15 PM   #7
sjarrett71
sjarrett71's Avatar
Mine was rusted like that but due to my own welding limitations and finances I got a different cab.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 06-26-2009, 06:04 PM   #8
tim21391
tim21391's Avatar
how is floor. corners. rockers and pillars?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-26-2009, 09:40 PM   #9
bddcustoms
bddcustoms's Avatar
floors, rockers will need repair -- but strait forward, and supported by after market patches.
Old 06-27-2009, 08:26 AM   #10
bddcustoms
bddcustoms's Avatar
More pics -- interior
Old 06-27-2009, 08:44 AM   #11
woodman13
woodman13
Looks like 80-100 hours of work. What does a drive to west texas/arizona take. 30 hours round trip? I would buy a good cab from someone in AZ or TX and drive to pick it up before I would attempt to repair that one. The rust you see is the tip of the iceberg.
Total driving and buying you would have less than $500 in a good cab and be far ahead of where you are now. My .02 Good luck!
Woodman13
2007 Dodge Ram 3500 5.9 rolling coal!
1994 Caprice 9C1 88K miles, LT-1, dropped/shaved
1967 C-30 350 4 sp dually
1971 C10 SWB BBC, auto; good driver
woodman13 is offline   Reply With Quote
Old 06-27-2009, 11:51 AM   #12
GruntMoanCough
GruntMoanCough's Avatar
Precisely. The rust that can be seen in those seams is not good or even safe.
You will either end up not repairing the rust not seen or.......you will be so deep into your repairs that there's no turning back and you'll be in a situation.
I suggest salvaging what you can from that cab and toss the rest of it.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 06-27-2009, 12:17 PM   #13
72BlckButy
Tot Roddin'
72BlckButy's Avatar
One thing I have learned.... it is money well spent if you can locate rust free parts. But, if you have the skills need for these repairs and don't mind putting in the time, I say go for it.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-27-2009, 02:44 PM   #14
bigsnookmaster
bigsnookmaster's Avatar
If you go with a new cab, [I would) you can always cut that one into parts and sell it on the parts thread, and you will probably be able to come close to making your money back. There was an ad on there recently, and they did pretty well, and you get to help a bunch of other people out. For what it's worth.Good luck
bigsnookmaster is offline   Reply With Quote
Old 06-27-2009, 03:41 PM   #15
68fixeruper
68fixeruper's Avatar
i have a 68 cab non ac if any1 is interested it needs cab cornors rockers the basic stuff not as far as this one is
68fixeruper is offline   Reply With Quote
Old 06-28-2009, 01:15 AM   #16
tim21391
tim21391's Avatar
id replace it thats a lot of work..
Old 06-28-2009, 05:22 PM   #17
Beatcoaster
69 Fleetside
Beatcoaster's Avatar
I'd say that is too much work - find another
Beatcoaster is offline   Reply With Quote
Old 06-28-2009, 05:33 PM   #18
(joey)
(joey)'s Avatar
i say dive right in.i had to replace both rockers,pas and driver floor pans,both cab corners, built a full legnth patch for inside where roof meets the windshield,had to remove and weld the whole drip rail,had to fab 80% of the lip the windshield fits onto,patch both kick panels and patch the firewall.and im almost done.and i did it all outside.
(joey) is offline   Reply With Quote
