Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-26-2009, 10:11 AM   #1
70stroker
70stroker's Avatar
c clip eliminators
How crucial are c clip eliminators, I have a 454 with a 177 blower 3600 stall and a 4:11 posi rear. Im takin her to the track tonight for the first time in a long time and with this setup. My mind keeps going to i should have c clip eliminators, i just finished body and paint last thing i want is a wheel and axle assembly to come flying out.
probably just have the jitters.
70stroker is offline   Reply With Quote
Old 06-26-2009, 10:09 PM   #2
71chevytruckguy
71chevytruckguy's Avatar
Re: c clip eliminators
IMO, very important. i snapped an axle at the track first i went with my '69. axle came out and i know have a huge dent in my bedside and tail gate. are you runnin slick or street tires? youd probably be alrite with street tires cause they wont hook good, but with slicks, id recommend c-clip elimantors and aftermart axles. Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 06-26-2009, 11:59 PM   #3
shortbed70
shortbed70's Avatar
So howd it go?????
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-27-2009, 01:15 AM   #4
70stroker
70stroker's Avatar
14.2 popping and running like crap.. lots of room for improvment i got a video ill post tomorrow. 2nd pass blew the trans.....
Old 06-27-2009, 05:13 AM   #5
71chevytruckguy
that sucks. sounds like the luck i have. if ya blew the trans 2nd pass, sounds like you've got enough power to do a lot better than 14's. hang in there. chris.
