Old 06-26-2009, 11:24 AM   #1
johny1i
D- or E-rated tires on K20
Hey guys,
My K20 is my daily commuter, and I seldomly pull a trailer--never anything more than you would pull with a C10 (4-wheelers, hopefully an 18' ski boat in the next year or two!). Question is--I've always been a believer in BFG A/Ts and the sizes I'm interested in are available as either D or E-rated. I have E-rated tires on it now, but I'm wondering if that is making the already rough ride of a 3/4-ton 4x4 unnecessarily worse. Cost isn't an issue--a 265/75-16 in those two ratings varies only by $4 each on Discount Tire.
Thoughts? I'm hoping a D-rated tire at 30-35psi will be an suitable substitute for a 45-50psi E-rated tire given what I use it for.
Thanks!!
'72 3/4-ton 4x4 LWB--my daily driver
johny1i is offline   Reply With Quote
Old 06-26-2009, 12:34 PM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: D- or E-rated tires on K20
I run mainly E on all my work trucks but I have had a few that originally came with D's and the ride was no different! On my smaller trucks that have those D or E's I dont run either fully inflated unless i am hauling and then just the rears.
Originally Posted by johny1i View Post
Hey guys,
Thanks!!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 06-26-2009, 10:57 PM   #3
johny1i
I hate to derail my own post, but I have to post a pic of my truck because it is uncanny how similar it looks to your suburban, 72Freak! I dig your paint scheme Thanks for the feedback--
Old 06-26-2009, 11:13 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Ihad some E tires on the back of my one ton for a while, when one popped (very loud, in the wrong part of town filled to 85 PSI) I replaced them with some tires off a lete model Tahoe or something. I don't know the rating off the top of my head, but it was instantly SO much nicer to drive. I think the max pressure on them is like 45 or so.
Old 06-26-2009, 11:53 PM   #5
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I'd go for the e rated.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 06-27-2009, 12:04 AM   #6
gerfunken
gerfunken's Avatar
Just play with the tire pressure. When I'm running my load range D tires around town, I typically keep them between 35-40 PSI. When I drop a load in the back, I make sure that I air them up to a minimum of 60 PSI. The pressure will change the amount of "give" your tire has, and by adjusting up or down, you can change your ride significantly.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 06-27-2009, 02:27 AM   #7
CCCC
CCCC's Avatar
The heavier ply rating (E) is primarily a loading factor and it sounds as though you do not deal with any loads beyond what the "D" rated tire would easily handle. Depending on the brand or manufacturer, there may be little to no difference in the ride characteristics of D and E.
But, air presssure is a different matter. If you reduce either tire from 45 psi to 30 psi (33% reduction) you will feel somewhat mushier handling with a bit more "in the road" feel, reduce fuel mileage a bit, and maybe get a little softer ride. But, IMHO with a tightly sprung 72 4x4 you are not going to soften the bumps very much by going down to 30 psi.
That is a very good looking truck.
CCCC
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 06-27-2009, 05:23 AM   #8
Load range D is fine,even if you haul some.Just use proper air pressure.I run my tires below max by 5 at least
