Old 06-26-2009, 01:59 PM   #1
Aunt-Jemima
8 lug disc brakes?
Why doesn't anyone make a 8 lug disc brake kit. I dont really see any reason why not besides maybe strength. but new trucks do and there isnt that much load on the front end besides maybe steering side load? But even that wouldnt be anything to worry about
1969 c20 350/th350(shift kit) A/C cab custom headers and exhaust
1972 c10 307/th350 (wrecked) possibly selling
Aunt-Jemima is offline   Reply With Quote
Old 06-26-2009, 03:56 PM   #2
Aunt-Jemima
Re: 8 lug disc brakes?
anyone have discs on their 3/4 ton?
Old 06-26-2009, 04:03 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
not enough people building them up.
You can swap the front end parts off any 71 - 87 3/4 ton and then install new parts. Not real hard.
Old 06-26-2009, 04:09 PM   #4
Aunt-Jemima
What do you mean by parts? can i just do knuckles of do i have to go a-arms and everything?
Old 06-26-2009, 07:24 PM   #5
justcuz
justcuz's Avatar
If you are going from 3/4 ton drum to disc, you should be able to get by with a spindle, caliper, rotor swap. You may need the tie rod ends out at the spindle too. If you are converting a 1/2 ton you are gonna need the lower control arms and tie rod ends for sure. The 3/4 tons have bigger lower ball joints.
justcuz is offline   Reply With Quote
Old 06-26-2009, 07:26 PM   #6
Aunt-Jemima
oops yeah i ment spindle not knuckle
Old 06-26-2009, 08:41 PM   #7
danw210
69 K20
Brothers has the conversion kit (#DBC8L20). It comes with spindles, tie-rods, ball joints, rotors, calipers, everything you need for $999.
danw210 is offline   Reply With Quote
Old 06-26-2009, 09:32 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Goodnight, 999 dollars for 8 lug disc brakes. I tried to give away a set last year. No takers. Every 3/4 ton from 71-87 will work as a bolt in donor. Even if you pay a couple of hundred for the donor parts and then go crazy at the parts store rebuilding everything with all new parts, you will still be under half that price.
Old 06-26-2009, 09:45 PM   #9
Beefcake
wow... i feel special right now. my 8 lugger has front disk.
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 06-26-2009, 10:59 PM   #10
danw210
69 K20
Special as in different??? I'm right there with ya bud!
Old 06-26-2009, 11:09 PM   #11
Longhorn Man
is it all that special? Every one built since late summer of 1970 has them.
Old 06-26-2009, 11:12 PM   #12
Aunt-Jemima
Hm. i might be searching some junkyards for some parts then
Old 06-27-2009, 03:03 AM   #13
ERASER5
ERASER5's Avatar
I have to disagree. I have $900+ in my disc swap using donor A-arms, spindles and drag links. I put in new everything else. I kept the track of all costs. Now if you used the old unknown junk yard parts, you can save money today, but pay it later.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-27-2009, 05:05 AM   #14
No,you meant knuckle .The spindle is part of the knuckle and you need the whole thing.They aren`t seperable.
I can`t imagine having $900 into new bearings,seals,rotors,calipers(rebuilt),ball joints,tie rod ends,and used knuckles/backing plates.And,it`s more likely to find used assemblies that are good to go than needs everything replaced.Other than calipers,it`s not unusual to get 100,000 miles or so out of the wear parts.It`s as likely the parts were recently replaced before the owner gave up on the truck or wrecked it.My last C/20 went down with all those parts fairly new.I see alot of members here swapping to 1/2t wanting to off their assemblies.There`s certainly no reason to blow nearly a grand on a Brothers "kit".
Old 06-27-2009, 02:41 PM   #15
justcuz
justcuz's Avatar
Technically Special K is right.
I refer to a 2wd as a spindle because it is a given today that they are cast together. Some disc brake AMC stuff seperates.
In a 4wd the spindle and knuckle are seperate pieces and do come apart. (except in some 4wd's that do not have a spindle at all, just a unit bearing and a knuckle.)
I don't think there is any confusion now though!
Old 06-27-2009, 09:28 PM   #16
hicktownhotrodder
Rollin Coal
hicktownhotrodder's Avatar
reman calipers are $20 at napa
I have three letters to all these import guys:
God-Made-Chevy
04 GMC Sierra 2500HD Duramax
1972 Chevrolet C-30 Dually Pickup stock? 350 SM465 four speed
1977 GMC K-35, TH-400, 4X4 450 horse 454(dad's)
1993 Dodge cummins 5-speed DEAD!!
hicktownhotrodder is offline   Reply With Quote
