Old 06-26-2009, 04:18 PM   #1
jlcelaya
Help! 72 rear end swap.
I have a 72 2wd c1o. And i want to put in a posi and 373 or 410. What rear ends would just bolt up and fit. Whats the best way to accomplish.sorry in new to c10 trucks.anyone.thanks.
jlcelaya is offline   Reply With Quote
Old 06-26-2009, 04:22 PM   #2
JimKshortstep4x4
Re: Help! 72 rear end swap.
My suggestion would be to swap in a posi carrier and the 3:73 gears.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-26-2009, 05:03 PM   #3
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Jim
That may be true but if you can't do the work your self, and it's not real easy, you might be money ahead to roll a complete one under there. Guess it depends on the deal you get on the other rear end. By the time you get the carrier, gears (not a fan of using used gears) and have it installed....you could probably pick up an entire truck for that amount (a beater of course). It's fun to go look at turds and throw a jack under them to spin the tires and see if she's a posi. It's an old trick but fairly accurate. If you jack up the rear end and chalk the tire, spin the pinion yoke exactly 1 rotation....if the tire goes around about 3 3/4's time....it's a 3.73!!!
prostreetC-10 is offline   Reply With Quote
