Old 06-26-2009, 05:53 PM   #1
fine 67
Junior Member
some help
on my 72 blazer i'm remounting my volt regulator and the silver thing that plugs into the bottom " capasitor' not sure were it mounts to be OEM. it only been sitting 12 years . YES i posted this on the blazer site and had no luck thanks mark
fine 67 is offline   Reply With Quote
Old 06-26-2009, 06:07 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: some help
The one I had just bolted to the regulator. However, a better recommendation is to ace the whole shootin' match and pick up an internally regulated alternator for about $40. The rewire is simple and will yield YEARS of problem free regulating/charging!
69GMCLonghorn is offline   Reply With Quote
Old 06-26-2009, 07:01 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: some help
I've considered doing this swap, when you go to the part store what year model do I give them so I get the right alternator?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-26-2009, 07:22 PM   #4
fine 67
Junior Member
Re: some help
thanks, do you witch hole . i try to do a 1oo % factory oem restore.
