short spark plugs
#5 plug boot resting on header, looking at all options to work this one out and was wondering if anyone has opinions on short spark plugs and wich one to use, 71 c10, 350, eps man, 1406 carb, hedmans, HEI, pulling my hair out all sugestions are appreciated
Re: short spark plugs
ACCEL Shorty Plug For Headers. you can get then at any parts store, about $30. Im using a set on my truck. they seem to work really well.
1971 GMC ![]() 1972 Small Blocked DATSUN 240Z Dads old car ![]() |
is the gap the same
We sell them $16.00 plus 4.50 shipping for 8
number 8199 Last edited by mbgmike; 06-26-2009 at 06:51 PM. |
Yeah same gap. I thin .045???
Thats a hell of alot cheaper, I know where I'll get mine now.
Had similar issue and the accel shorties solved the problem
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
If you have vortec heads they won't work.
they work on mine just fine man.
Is there a reason they wont work? will they mess up a head or what?
The only ones I could find to fit mine were 15 bucks apiece, all the ones at local auto parts set to deep
Ok got what your saying.
Parts and more parts
#13 |
Restoration Virgin!
Been reading a bit on the accel shorty plugs.....lots of people say they foul out ALOT!!!....
has anyone used these? Champion Spark Plug numbers: RV91MC and RV92YC They are the same length, just better from what I read!!!.....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 06-27-2009 at 10:30 AM. |
#14 |
Trucks N Tranzams
I am posting this at the risk of getting flamed, like I did last time.
This is a copy of a PM I got from another member concerning spark plugs. I have used it with great success. This site is also a source of good info. www.sparkplugs.com My only problems with Champion and ACCEL, were the insulators cracking during installation. "Did you get angled or straight plugs? That is the main deciding factor. I use Autolite 3924's based on Edelbrock recommendations. (I've always had good luck with autolite plugs, so I stick with them) If you have the angled plug heads, you'll probably have to use a shorty plug. Here is the recommendations from edelbrock. I believe the plug seats are flat, so you should use the washers (if they are tapered seats, you don't use the washer...) Under 9.5 to 1 Compression Champion ---------- RC12YC / 2071 NGK --------------- FR 4 / 5155 OR BCPR5ES / 6130 Autolite ------------ 3926 Motorcraft --------- AGSFP52 Accel Shorty ------- 0416S Up to 10.5 to 1 Compression Champion ----------- RC9YC / 2075 Autolite -------------- 3924 NGK ----------------- FR 5 / 7373 OR BCPR7ES / 3330 Accel Shorty -------- 0414S 11 to 1 Compression Champion ------------ C63YC / 796 NGK ------------------ R5672A-8 / 7173 12 to 1 Compression Champion ------------- C61YC / 785 NGK ------------------- R5672A-9 / 7405 " __________________
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
#15 |
I have been running the Accel shorty plugs in my 383 stroker motor and my son's 350 motor for years. It may be true that some people have had fouling problems with their plugs, I have NOT had that happen YET. (Knock on Wood---I guess). I have put many miles on my engine and it does have a larger cam than most stock engines. So, a fouling issue would be noticeable if it happened.
#16 |
I use Accel #8199 shorty header plugs
#17 |
I was wrong when I said I use them with no problem.
Did some digging on the net. plugs that work in older heads pre 1996 wont work in vortec. vortec heads need a plug with a longer reach, not shorter. A plug with a short reach will burn up the threads the plugs screw into. causing head failure. At least this is what I have read.
