Old 06-26-2009, 07:11 PM   #1
Nova70
Nova70's Avatar
Am I missing something?
I went to do the front cab mounts on my '70 today and I'm having a problem... The nut is on the bottom of the cab but the top of the bolt should be on the cab floor correct? I peeled the carpet back to get to it but there's no bolt there... Pulling back the carpet revealed there's a new piece of sheet metal half assly welded there and I think he covered up the bolt... If I'm wrong could someone tell me where to locate the nut?
Nova70 is offline   Reply With Quote
Old 06-26-2009, 07:18 PM   #2
msgross
msgross's Avatar
Re: Am I missing something?
Sounds like they installed a floor pan on top of the bolt head... You're gonna have to find it and use a hols saw to cut that metal..
This is assuming that there is a body mount under there and you can see the bolt and nut under the cab next to the frame...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-26-2009, 07:26 PM   #3
Nova70
Nova70's Avatar
Yeah there's a body mount. That's what I thought but I was just making sure before I go cutting holes where I don't need to. Thanks.
Old 06-26-2009, 07:27 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Nova70 View Post
....... If I'm wrong could someone tell me where to locate the nut?
Are you talking about the big nut behind the wheel? I have found it's fairly easy to locate if you use a mirror
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-26-2009, 11:12 PM   #5
RW71
RW71's Avatar
Hear is a pic.
RW71 is offline   Reply With Quote
Old 06-27-2009, 02:18 AM   #6
Nova70
Nova70's Avatar
Im gonna try and draw a diagram but I don't know how this will work... lol.
Old 06-27-2009, 08:01 AM   #7
msgross
msgross's Avatar
Here is the bolt hole, new floor pans don't have a hole drilled so more than likely he layered your floor pans instead of cutting out the old floor and then welding in the new one, then drill the hole for the bolt. Yes, the bolt head should be visible.
The Garage:
Old 06-27-2009, 08:52 AM   #8
So,the p.o. "shaved" the mounting bolt location.
Old 06-27-2009, 02:47 PM   #9
Nova70
Nova70's Avatar
I thought so but my dad insisted the bolt was not in the cab... ? Thanks for the help... Now to measure and hope it works. I guess I'll get a hole saw and try and measure out where it's at. Shouldn't be to hard.
Old 06-27-2009, 03:33 PM   #10
dfwright
dfwright's Avatar
Is the bolt not welded in on the 70 like it is on the 72?
On mine I wouldn't need to get to the bolt head to torque down the nut.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 06-27-2009, 04:15 PM   #11
msgross
msgross's Avatar
why not snap some pics first and show us what you are working with...
The Garage:
