Dash pad removal
I dont want to break aynthing, but the removal of the dash, i just quickly looked at it , how does it come out? i want to pull the whole dash pad off.
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
Moderator
![]() Join Date: May 2007
Re: Dash pad removal
It is bolted to the dash, underneath, as well as the screws you see on the front. You will need to remove the glovebox, gauge cluster, radio, and A/C center vent if applicable. A small socket tool with an extension and a wag works best. They are in tight spots, but it is do-able. I just did this about a week ago.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Unfortunately the dash pad goes on first and comes off last. I have removed one without taking everything else off first and would never do that again.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
