06-27-2009, 12:30 AM | #1 |
What does this switch do?
Hey wondering if anyone knows what this switch is for or what it does, I have no clue, never seen it before. It's mounted to the gas pedal bracket and from what I can see it appears as though when you step on the gas pedal (accelerate) it hits this switch. I haven't looked at any diagrams yet but thought I would run this by everyone for some help. Here are the pics and this is a from a 1971 1 Ton Dually just in case that may have something to do with it. Thanks
06-27-2009, 12:36 AM | #2 |
TILT COLUMN GURU
Re: What does this switch do?
Kick down (passing gear) switch for Turbo 400 tranny
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
06-27-2009, 12:44 AM | #3 |
I've got one on my truck too, How are they suppose to be adjusted?
06-27-2009, 12:46 AM | #4 |
Ah that makes sense now I knew it was something pretty simple, thanks very much.
06-27-2009, 12:48 AM | #5 |
I think you can slide it on the bracket can't you, I'm not to sure I'll have to take a closer look. I never worked with a TH400 before so it's pretty knew to me.
06-27-2009, 05:53 AM | #6 |
its all about the +6 inches
other than fpr damage... why would you need to adjust it?
