Old 06-27-2009, 12:42 AM   #1
bubbletop1961
bubbletop1961's Avatar
skinny chevy truck ralleys?
1st off, I hope this is in the right section. I was wondering about skinny chevy truck ralleys. Ive never seen them but would be intrested in some. I think I have a local place to go ask about doing it, but has anyone on here done it already or better yet, sell them?
http://profile.myspace.com/index.cfm...ndid=186313550
Current project is for sale. 4" chop, channelled, lowered 5", http://67-72chevytrucks.com/vboard/s...d.php?t=347067
bubbletop1961 is offline   Reply With Quote
Old 06-27-2009, 12:55 AM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: skinny chevy truck ralleys?
Van ralleys are skinnier than trucks and look the same as truck.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 06-27-2009, 01:02 AM   #3
bubbletop1961
I have a full set of 8's, And I know 7's are out there. Im kinda wondering about 4-6" wide. The big and little look.
Old 06-27-2009, 01:17 AM   #4
70stroker
70stroker's Avatar
i got 6x 15 on the front of mine with 12x 15 on rear
70stroker is offline   Reply With Quote
Old 06-27-2009, 01:30 AM   #5
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Stroker......you have car style rallys though.....he is talking about the truck rallys!
prostreetC-10 is offline   Reply With Quote
Old 06-27-2009, 09:29 AM   #6
paps69
I have a pair of 4" 6 lug truck ralleys I might part with. They have new rubber on them.
paps69 is offline   Reply With Quote
Old 06-27-2009, 09:38 AM   #7
I know they made the 15" ralleys in 6.5" (van), 7, & 8 (trucks) widths. I have not heard of or seen any different widths than that from the factory. You can however get them from places like Stockton Wheel and Wheel Vintiques.
Old 06-27-2009, 09:46 AM   #8
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I have narrowed and widened rims for myself and for friends. It's easier with more rims than is required. Requires big lathe with a swing more than the diameter of which you are turning .To make a set of narrows save two outer rings from two sets of rims cut off in the lathe. Weld the two rings together then weld in your center. Making them fatter, cut out the center from the inner and outer ring add a piece of flat stock between the outer and inner ring to the dimension desired then weld in your center. The lathe is the secret.
Old 06-27-2009, 10:06 AM   #9
turp mcspray
turp mcspray's Avatar
Both of these places will make whatever you like. A friend has a pair of 4" he bought from Wheel Vintiques. And they are very reasonable.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 06-27-2009, 10:31 AM   #10
bubbletop1961
Ill check into these. MIght be good enough for what Im doing. Ill also check out the other co's. Go figure I am going to have a little tire clearance issue with this project! Who didnt see that coming. lol.
Old 06-27-2009, 12:47 PM   #11
mbgmike
Yeah we made 9.1/2 wide ones doing it exactly like you sad.
mbgmike is offline   Reply With Quote
