Old 06-27-2009, 11:08 AM   #1
El Jay
Gone to greener pastures
Distributor Problems
Here's the background: When I bought my '69 it had an Accel distributor. I don't remember what the problem with the distributor was, but I swapped it out for a complete MSD system; spark box, distributor, Blaster coil, plug wires; firing Accel shorty plugs.
My problem is, about every 4 months, or so, the carbon button in the distributor cap is burned up so I have to replace the cap & rotor; which is getting expensive.
So far, nobody has been able to give me any reason why this is happening.
I e-mailed MSD tech support & they said it may take up to 48 hours to get back to me. It's been over a week & still no response.
Doing a little research, I've learned that the spark plugs (when doing a tune up, I just replaced "like & kind") I'm using are non-resistor plugs.
Could this be the cause of my problems?
Any input at all would be greatly appreciated.
Thanx,
LJ
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-27-2009, 11:39 AM   #2
neonlarry
neonlarry's Avatar
Re: Distributor Problems
Have you checked to see if the rotor contact is making good contact with the button on the cap? If not put a dab of dielectric grease on the rotor contact and install the cap, then remove and check to see that the impression in the grease goes all the way to the metal of the contact.
Also check all your grounds carefully (shiny metal to shiny metal).
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-27-2009, 11:50 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This thread was posted by slammed70 last year and he had the same problem. I found a forum where they suspected the plug wires for the cause. I never did get a hard fast fix on it. You might PM slammed70 and see if he found the cause. VV
http://67-72chevytrucks.com/vboard/s....php?p=2904910
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-27-2009, 12:26 PM   #4
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
As we all know....electrical can be the worst to diagnose. I'm wondering if a weak system can cause the build-up? I'm shooting in the dark here but have you taken out a plug, pushed it into the boot and held it against your block while turning over the motor? I have a complete MSD setup too. It really changes the energy of the spark. Each time my rotor hit that plug, it lit it up like the end of your cutting torch. It would be interesting to know if you are really getting a high energy multiple spark.
Seems like battery terminals corrode when there is a weak connection.
prostreetC-10 is offline   Reply With Quote
Old 06-27-2009, 12:36 PM   #5
El Jay
I already did that. I really appreciate you offering the suggestion, though. There has to be a simple solution that I'm just overlooking.
As a side note, you coming down here to cousin Jerry's in 2 weeks? We all met at Roseville. I had the ugly, POS long step.
I pulled the plug wires & checked the resistance. All were good, except one. My multimeter showed that it was open. I wouldn't think that 1 plug wire would cause all these problems; & the plug wires were installed the same time as all the other ignition parts.
Thanks for getting back to me.
LJ
Old 06-27-2009, 02:15 PM   #6
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
This may sound simple but have you tried running a set of resistor plugs instead of the non resistor?
1970 Bowtie is offline   Reply With Quote
Old 06-27-2009, 02:47 PM   #7
El Jay
That's my next step.
What's making me crazy is, although they are 3 years old, the wires, etc., don't have very many miles on them.
I'm kinda, sorta, in my mind, thinkin' about a cross country trip to visit my kids.
I don't really want to have to carry 3, or 4, extra caps & rotors (ever notice that rotor spelled backwards is rotor: how palindromic is that?) to change out on the road when the truck starts running like crap.
Old 06-27-2009, 04:38 PM   #8
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Just a possible thing running through my mind , maybe the non resistor type have,well, too little resitance, which makes an arc thats bigger than would be with resistor style plugs, resulting in carbon build up haha confused myself. My next step would be go buy some cheapy champion copper head plugs and see how long it takes till you have to change the rotor and cap etc etc
mikajo39 is offline   Reply With Quote
Old 06-27-2009, 05:46 PM   #9
Longhorn321
Size Matters
Longhorn321's Avatar
I would think increasing the resistance would make the spark hotter. An old timers trick to getting a fussy engine to start is to pull the plug wires off a little bit. This is supposed to make the spark hotter. Also, if you have your plug gap to small, the plugs will foul because the spark is not hot enough...bigger gap=more resistance. I don't know what more resistance would do to the cap and rotor tho...seems like there should be no arcing there so I don't know why there would be build up there.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 06-27-2009, 06:02 PM   #10
mikajo39
mikajo39's Avatar
well by arcing I was thinking it does happen just to a controlled extent because when the rotor strikes the terminal in the cap its gotta spark kinda like touching to jumper cables together just a lot faster lol . could be a lot of things hopehe gets it fixed whatever it is must be a pain
Old 06-27-2009, 06:40 PM   #11
WorkinLonghorn
WorkinLonghorn's Avatar
I'm not at all familliar with MSD but if the button is burning up then we know there is lots of arcing going on there,which will not happen UNLESS there is a space between the two contacts.
So you either have a weak spring under the button,the button is hanging up,or the bushings on the distrib are shot and the rotor is bobbing up and down.Of course it's kind of hard to picture the thing since I haven't had my distib off in a long time so I'm probably way off,except that I'm sure you have a gap in there.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-27-2009, 06:43 PM   #12
gizmo1
the carbon button is causing the problem, get a special one from msd that will cary the current
gizmo1 is offline   Reply With Quote
Old 06-27-2009, 07:32 PM   #13
El Jay
MSD doesn't make a replaceable button for the "small" (think GM "window sized" cap). They only make the button for the bigger HEI sized cap.
I checked that option 2 caps back.
But I do appreciate your input.
KJ
Old 06-27-2009, 07:58 PM   #14
fixit-p
fixit-p's Avatar
MSD makes this cap for point style dizzys I have on on my factory dizzy on my 69 it's seems pretty stout and the HEI style towers are also a plus IMO>>>http://summitracing.com/parts/MSD-8433/
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 06-28-2009, 11:47 AM   #15
Longhorn321
Size Matters
Kinda what I was thinking too....could you lubricate the button where it moves up and down?
...WOOOO HOOOO!!!!
Old 06-28-2009, 03:12 PM   #16
El Jay
That is the cap that keeps burning up the button.
I thank you for trying to help.
Like I said in an earlier post, I put dielectric grease on the button & installed the cap; removed the cap & there was grease on the rotor.
I'll have to check the spring on the button tomorrow morning.
It's over 100 outside today. No need to punish myself more if I don't have to.
And, thank you.
That's what I love about this place; post a question about a problem & you'll get a whole mess of, "try this, try that, lookie at this" type responses.
Everybody tries to help.
LJ
Old 06-28-2009, 03:15 PM   #17
mikajo39
mikajo39's Avatar
Same here was going to get out and work on my truck today, not gonna happen today for sure. But it does make a good time to do some online research and beat the heat.
Old 06-28-2009, 03:25 PM   #18
El Jay
I'm maybe 50 "road" miles away.
Heckuvalot closer as the "crow flies."
Just think east Contra Costa/Antioch!
Old 06-28-2009, 03:29 PM   #19
Longhorn321
Size Matters
LJ
Sorry, I musta misunderstood. I thought you just put grease on the end of the button to see if it was making contact with the rotor. I was talking about where it slides in and out of the cap.
...WOOOO HOOOO!!!!
Old 06-28-2009, 03:29 PM   #20
mikajo39
mikajo39's Avatar
Dang that is pretty close!
Old 06-28-2009, 03:36 PM   #21
El Jay
There sure ain't no need to apologize!!!!!!!
You were trying to help a total stranger.
Yup.
I'll be in your 'hood this week.
I actually get to work on Wed., I'll be at Homie Despot as my last stop Wed. afternoon.
Old 06-28-2009, 03:41 PM   #22
Longhorn321
Size Matters
Hey here is another thought...when you go to check that spring, spin the motor over while you have the cap off and see if the rotor seems to be bobbing up and down like WorkingLonghorn suggested.
...WOOOO HOOOO!!!!
Old 06-28-2009, 04:13 PM   #23
El Jay
I can do that!
The biggest thing that is making me crazy is this whole system don't have 10K miles on it. And yeah, I know, even new stuff can be "bad".
Old 06-28-2009, 04:18 PM   #24
royo
royo's Avatar
KJ
?? a msd dist should allready have the good button in it right . The one i just bought has it in it
nickle and dime
royo is offline   Reply With Quote
Old 06-28-2009, 04:24 PM   #25
Longhorn321
Size Matters
I can do that!
I hear ya. I'm curious now tho so you gotta post what fixed it.
...WOOOO HOOOO!!!!
