Question about front springs
Iam new to this but I have a question about front springs i have a 1969 Suburban that had a 327/400turbo in it and iam putting a 402 big block with a 400 turbo in it and the question is will the small block springs hold the big block and if so will it lower it cause of the weight? and if it does about how much will it lower it? I would like to lower the front 3in
Re: Question about front springs
#3 | |
you will be fine with your springs
its all about the +6 inches
it'll lower no more than with a small block and the average 200 pound man sitting on the hood.
1/2 inch or so tops. |
My Carbon Footprint
I did the same thing you are talking about. I was amazed at how much it DIDN'T lower it. You will probably notice a difference in spring rate than the ride height......if any.
thanks guys for your help and should i start a thread on the burban?
'69 Suburban 2wd (on hold) '71 Chevy C-10 2wd lwb have a pair of them(on hold) '63 Chevy C-10 4wd on a '78 blazer frame '71 Chevy C-10 4x4 4 inch with 33's '68 Chevy C-10 2wd lwb '03 Chevy Crew Cab 4X4 Duramax (DD) |
#7 | |
My Carbon Footprint
Of course you should. Ever notice the viewed -vs- replies column? Lots of people can learn from build threads just by looking. I've picked up some great ideas and also learned what NOT to do. |
