05-19-2002, 07:27 AM | #1 |
lowering Springs
I used lowering springs on my 71 cheyenne 3&4" when I lift the truck off the ground the springs get loose and fall to one side, to lower the truck I have to hold them in place and lower it is this normal? Thanks Joe
05-19-2002, 07:36 AM | #2 |
Got 20's????
There is nothing you can do except get drop spindles. I heard that you can remove the upper bump stop on the upper a-arm and run a bolt through there instead. Just use a very long bolt and when you jack it up it will hit the pod that comes off the frame and won't allow the suspension to sag that far.
------------------ 72 Chevy C/10 87 Chevy Silverado 4X4 www.geocities.com/chevylwb/chevylwb.html Aberdeen South Dakota WANTED: Drop Spindles F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
