Vintage Air question...
I would like to know if the old fresh air opening on the passenger side where the heater box used to be is the same fit/size for vintage air.
I am currently installing new metal both the outer and inner panels. The replacement inner panel has the opening but does not have the same recessesed edge. ![]() |
Re: Vintage Air question...
i've got VA in mine and the same vent they don't actually connect VA just moves the air around in the truck there is no out side air pumped in. mainly cause there are some many holes and gaps in the cab. you will get plenty of fresh air so long as your moving....
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
#3 | |
Thank you. |
