Old 06-28-2009, 09:51 AM   #1
68c10guy
68c10guy's Avatar
Vibrations after tranny swap
yesterday i swapped a brand new rebuilt th350 into my truck. it is a midly built tranny and it has a 2200 boss hog torque converter. Here is my problem, there is a vibration. at any speed it kind of pulses. it does this in park when i rev the engine too. any ideas?
68c10guy is offline   Reply With Quote
Old 06-28-2009, 10:18 AM   #2
68fixeruper
68fixeruper's Avatar
Re: Vibrations after tranny swap
torque convertor is what id check first make sure bolts are good if everything is ok with the bolts you still could have a bad torque convertor
68fixeruper is offline   Reply With Quote
Old 06-28-2009, 11:43 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I would unbolt the converter, and rotate it to the next hole, then bolt bolt it back up.
Old 06-28-2009, 03:05 PM   #4
JCA1972
JCA1972's Avatar
I had the same problem when I swapped my manual to an auto. This is what I did to fix it.
I removed the dust cover and loosened the converter bolts, and then I slowly re tighten them by tightening one a little bit then the other, kind of like when you tighten a wheel.
Thats all and the vibration stopped. Its worth a try.
1971 C-10
2004 Yukon:
1998 Honda Accord
2008 Honda Civic
2004 HD V-Rod
http://67-72chevytrucks.com/vboard/s...d.php?t=226458
JCA1972 is offline   Reply With Quote
Old 06-28-2009, 10:57 PM   #5
68c10guy
68c10guy's Avatar
i tried loosening then retightining. i will try the hole idea thoug. Anyone have any mor input? Thanks for everything!
Old 06-28-2009, 11:18 PM   #6
GruntMoanCough
GruntMoanCough's Avatar
Did you happen to change your flex plate as well?
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 06-29-2009, 11:22 AM   #7
68c10guy
68c10guy's Avatar
No flexplate was same as last transmission, and i had no vibration with that one.
Old 06-29-2009, 12:11 PM   #8
GruntMoanCough
..........just a thought.
Could it possibly be internal? I don't know how, maybe talk to your tranny guy.
