Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-28-2009, 03:12 PM   #1
AlienYouth
AlienYouth's Avatar
cam question
So I am finally gonna have some time to work on my junk and put it back together! I'm putting a roller cam in because I trashed my flat tappet, so far i've come up with the CS XR274 R-10. I'm not really looking for cam suggestions, but more of wondering how much lift is safe/reliable for a truck that gets driven a good bit. It's a solid roller cam and has .602 / .608 lift after my 1.6 rockers. Am I going to create problems with this much lift? I'll obviously check piston/valve clearance, I'm buying the matching springs and will get a stud girdle and anything else you guys suggest
Thanks in advance
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 06-28-2009, 04:21 PM   #2
shortbed70
shortbed70's Avatar
Re: cam question
Hope you have some compression in your motor! I think even being a roller it looks big but whats the duration rated at? Unless your heads flow up there and your motor can turn 7000 rpms with 11-1 comp its probably going to be a dog. Do you have 1.5 now or 1.6?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-28-2009, 10:22 PM   #3
AlienYouth
AlienYouth's Avatar
Re: cam question
i have 1.6 rockers now, and it is alot of lift, but the duration is only 236/242 at 050... so isn't that "big" of a cam like you're thinking, just a bunch of lift. My motor is 9.5 CR and Iron Eagle 180 heads under a dart kool can, i'm pretty sure this cam is just about right, just wondering if there are gonna be issues with this kind of lift
Picturesss
71 C10 383/TH400
Old 06-29-2009, 12:02 AM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
Re: cam question
My 383 is currently runnig a Crane hydraulic roller very similar to that on a 112 CL. and a wise LSA. It's pretty street frendly but I run a pretty loose convertor and some wild gears. The ramps on a hudraulic roller arent as harsh on the springs as a solid. IMO .6 lift is piece of cake, but keep in mind extreme high rpms and heat are NOT your friend here. If you used oil restrictors, remove them. You want as much oil flow to the top end as you can get here and things will be happy for a good long time.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-29-2009, 05:14 PM   #5
AlienYouth
AlienYouth's Avatar
Re: cam question
sweet, thank youu, i'm not using restrictors, and i have a ~3000 stall converter and 3.73's with some pretty short tires, i think it'll still have enough bottom end to be fun on the street. I haven't ordered my stud girdles yet, any u would recommend/stay away from, and are they really needed here? thanks alot
Picturesss
71 C10 383/TH400
Old 06-29-2009, 05:24 PM   #6
Marv D
Marv D's Avatar
Re: cam question
With the mild spring pressures of a hydraulic roller, I wouldn't call them 'needed' but can be good insurance. As is a hydra-rev kit to keep things in check at higher rpm's. In fact, I'd spend the $'s on a hydra-rev kit before I'd do the girdle, but 'both' would be 'absolute best'
Old 06-29-2009, 05:36 PM   #7
AlienYouth
AlienYouth's Avatar
Re: cam question
well, thats a solid roller cam, so probably just the girdle then? thanks again, u make me think less
Picturesss
71 C10 383/TH400
Old 06-29-2009, 06:19 PM   #8
shortbed70
shortbed70's Avatar
Re: cam question
Yea thats not alot of duration so you should be fine. If your pushin rpms pretty hard girdles are nice to keep everything inline but for the street I wouldn't think they would be necessary. I would be more interested in the rev kit myself. Good luck.
Troy
Big Red Dog build
Old 07-03-2009, 11:19 AM   #9
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: cam question
http://67-72chevytrucks.com/vboard/s...d.php?t=347969
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
