06-29-2009, 12:04 AM | #1 |
need help
have 1972 c10 cheavy truck need help tail lights and brake lights dont work but turn nsignals do all bulbs replaced and all fuses checked and good
what should i look cor next what could cause this proublum |
06-29-2009, 01:37 AM | #2 |
Re: need help
id look at your ground.. if the ground is dirty take some sand paper to clean it up
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
06-29-2009, 08:19 AM | #3 |
Re: need help
I just fixd my tail light issues mine would work fine untill I put my lights and then nothing worked in back so we checked all the grounds and also had to replace most of the wireing harness that goes to the back lights
06-29-2009, 12:30 PM | #4 |
Re: need help
check for broken wires or wires without connectors
06-29-2009, 03:14 PM | #5 |
Re: need help
have 1972 c30 1 ton cheavy truck need help tail lights and brake lights dont work but turn signals do all bulbs replaced and all fuses checked and good
what should i look for next what could cause this proublum when tested with turn signal on using test light turn signal works when brake light applied it works but not with new bul in it i have 1157 bulbs for this are they the right bulb or do i have the wrong bulb |
06-29-2009, 03:15 PM | #6 |
Re: need help
what should i look for next what could cause this proublum when tested with turn signal on using test light turn signal works when brake light applied it works but not with new bul in it i have 1157 bulbs for this are they the right bulb or do i have the wrong bulb: |
