profeshinaly unimployed
horn
ok so the horn on my truck doesn't work cuz the switch in the steering wheel is broke...so what color is the wire to the horn and where is it located cuz i wanna hook it up to a momentary switch...ive realized not having a horn kinda sucks cuz now i gotta rev my engine to get ppls attention...witch is just a waste of gas lol
"having mud flaps is like asking for a smaller trophy" |
6.0 powered square
Re: horn
its a black wire thats wired in a pigtail for the turn signal and hazards under the steering column behind the metal access panel
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Re: horn
thanks, would u happen to have a pick at all?
#4 | |
Re: horn
____________________________________ |
Re: horn
ok i think i found it...so do all i have to do is cut it and then hook it up to a switch and 12v power
6.0 powered square
Re: horn
the horn wire is hot, so you'll need a horn button every part store should have one for a couple of bucks and a ground wire
the pollock
Re: horn
hey dude DONT CUT THE COLLUMN WIRE
jsut run a new one! ive done that with mine and i have a "stomp switch" below my e-brake cable.. super simple wiring man.. just make sure you run it off a fuzed powersource...(like radio etc) do not do not do not NO MATTER WHAT cut the wiring on yrou steering collumn.... it's a serious pain in the ass to fix for people who are "new" to it just my two cents..
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
Another Day, Another Dollar
Re: horn
have you considered fixing the horn?
as i recall the parts kit is relitivley inexpensive..
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
the pollock
Re: horn
p.s. stomp switches are cool as hell! because you can just stopm the crap out of your horn! instead of puncin your steering wheel!
#10 | |
Re: horn
the pollock
Re: horn
well if my truck was together i would take a picture..
it's simple.. you MIGHT have to make a bracket for the new switch.. i maze mine out of a "z" shaped peice of aluminum it connects to the side and the floor of my cab right below my ebrake... i ran a FUsED positive wire to the terminal on the momentary switch then run the ground wire to the horn blade connector the horn is self grounding to the truck itself.. OH if you are having horn issues pull and sand the connection between the horn and the fender where it is attached.. super simple "series" circuit... just remember to use a fuse. that "hot wire" can run a chance of shorting and burning your truck to the ground.. good luck dude!
the pollock
Re: horn
p.s. after all is said and done you can use someblack RTV on the back side of the momentary switch to make absolutely sure it dosent touch the cab floor whenevver you hit it..
you can also use it in different locations.. but i just have a undying love for a stomp switch
#13 | |
Re: horn
#14 |
the pollock
Re: horn
they are under 10 bucks at radio shack..
but if you ahve power to the switch.. and no sound at the horn.. do a voltage check at the horn connector (u can use a test light) press the horn button and see if it illuminates.. if it does.. pull your horn off the fender and sand the bolt location so you have a fresh ground
#15 | |
Re: horn
