Old 06-29-2009, 08:17 AM   #1
ob1monkey
turn signal problem?
hey guys I thought someone might be able to help me with my turn signals. I got in the 66 this morning and found that when I use either side they both flash like 4ways. I just did the bed swap. when I reinstalled the lights and wiring I made sure the grounds were good. and my wiring is in good shape no nicks. any thoughts would help.
ob1monkey is offline   Reply With Quote
Old 06-29-2009, 01:03 PM   #2
Captainfab
60-66 Nut
Re: turn signal problem?
Did they work correctly before the bed swap? If so then I would recheck all the wiring you delt with in the swap
Old 06-29-2009, 02:54 PM   #3
Longhorn321
Size Matters
Longhorn321's Avatar
Well I don't have a diagram of a 66 but I'm thinking the turn signal switch is the most lilkely culprit?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 06-29-2009, 03:14 PM   #4
ob1monkey
I am going to try removing and repluging the wires when I get home. the turn signal cam and assembly is only a year or so old so hopefully that is not the culprit.
Old 06-29-2009, 03:17 PM   #5
Longhorn321
Size Matters
Just doin a little research to try and help ya cause I ain't got nothin better to do ('cept work). You don't have a hazzard switch do you? Also, is your turn signal switch an aftermarket/add on accessory?
...WOOOO HOOOO!!!!
Old 06-29-2009, 03:27 PM   #6
ob1monkey
I appreciate the help no it's a faactory style in column turn signal assembly. no 4ways. I am really hoping that I just crossed a wire when I put it all back together.
Old 06-29-2009, 03:47 PM   #7
Longhorn321
Size Matters
I tried finding a wiring diagram online but couldn't find a good one with a factory turn signal switch that I didn't have to pay for. You don't happen to have one do you?
...WOOOO HOOOO!!!!
Old 06-29-2009, 03:47 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
Make sure your lite buckets are grounding.....I had a hell of a time getting my tails to work right. They will do all kinds of crazy stuff when not hooked up and grounded correctly.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-29-2009, 05:42 PM   #9
joe231
joe231's Avatar
it sounds like you have a bad ground and it is back feeding.
CHEVY ONLY
Old 06-29-2009, 08:32 PM   #10
ob1monkey
I will look into the grounds tomorrow I got called back to work for a sewer line backup so no checking it out tonight. I appreciate all the responses and advice the wiring diagram is great need to save that just in case.
Old 06-29-2009, 08:44 PM   #11
joe231
joe231's Avatar
I have a color '64 diagram around here somewhere.....I'll look and report back
CHEVY ONLY
Old 07-06-2009, 09:13 AM   #12
ob1monkey
thanks for all the replies. It's ben raining almost every evening so I haven't been able to look at it but I will sometime this week and let everyone know what it was.
Old 07-06-2009, 09:53 AM   #13
rendus
rendus's Avatar
http://67-72chevytrucks.com/vboard/s...36&postcount=5
rendus is offline   Reply With Quote
