![]() Join Date: Apr 2009
Dirct to metal fill primer
hello all, does anybody know of a direct to metal high build primer that comes in something other than grey? I'm gonna be driving around for a while like this so I was looking for red or something less boring than grey. Thanks in advance for any help.
Re: Dirct to metal fill primer
You should be able to get your grey primer tinted
we used green on my sons Camaro if you are going directly to metal you should use etching primer.
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
![]() Join Date: May 2007
PPG has or had a yummy mauve color.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Junior Member
I am not sure there is a "high build" primer that is direct to metal. I would check with a local paint supply store. Several high build primers can be tinted. I would use an etching primer first and then a primer filler but they are not made to with stand the weather without top coat.
1967 Camaro (in pieces) 1972 Chevrolet K/5 Blazer 1969 Chevrolet K/5 Blazer 2000 Chevrolet K2500 Crew Cab 454 1999 Chevrolet Blazer 2008 Polaris Ranger XP Orange Crush ![]() |
Whatever color you find, if your going to run it for awhile without a top coat, make the final primer coat an epoxy primer, the others will absorb water.
