Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-29-2009, 03:50 PM   #1
kev93
Any advice on how to pro street the rear of my stepside?
1977 Stepside. I want to run huge tires under her. Any advice on what I need to do to get it done would be greatly appreciated.
kev93 is offline   Reply With Quote
Old 06-29-2009, 07:42 PM   #2
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
Re: Any advice on how to pro street the rear of my stepside?
i have a 10'' wide steel pickup rim with a 12.50" wide M/T et street on a Stock width 12bolt in my 55' No other mods whatsoever to fit them(not the WIDEST but makes me smile more then the 8"'s of rubber i had)
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 06-29-2009, 08:36 PM   #3
CoggedBelt75
CoggedBelt75's Avatar
Not a stepside, but this is the setup on my '75 with the only frame modification being a c-notch......
truck 12 bolt
4-link and panhard bar
Koni coil overs
Flange to Flange:
mini spool
4.56 Richmond gears
C-Clip eliminator
Moser axles
Wilwood disc brake kit
Convo-Pro 15x14 4 1/2" backspace
Hoosier Pro-Street Radials 31x18.5R15L Tread Width: 14.5
The rearend was cut, and with Moser big ford housing ends installed, measures 44" end to end. Enough clearance to also run Hoosier 32.0/14.0/-15 drag slicks that are 16.3" wide. Hope some of this can help you out. Good luck with your project.
Joe
CoggedBelt75 is offline   Reply With Quote
Old 06-30-2009, 08:50 PM   #4
AirMale
AirMale's Avatar
4-link is cush.... can you weld?
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
