Old 06-29-2009, 07:18 PM   #1
Nova70
Nova70's Avatar
Adhesive's?
The clasp that holds the rear window shut popped off a couple days ago courtesy of the GF. I can't get anything to hold it back on. It will hold but then when I go to latch it the pressure pops it back off. I've tried rear view mirror adhesive and epoxy. I let the rear view mirror adhesive dry for an hour and the box says 5 min, I let the epoxy sit for 8 hours and the box says 8 hours... Any of you guys had this problem or have suggestions on what to use?
Nova70 is offline   Reply With Quote
Old 06-29-2009, 07:58 PM   #2
mbgmike
Re: Adhesive's?
A high quality Urethane like used in glass shops
mbgmike is offline   Reply With Quote
Old 06-29-2009, 08:41 PM   #3
GruntMoanCough
GruntMoanCough's Avatar
Re: Adhesive's?
On the same thing, I've tried windshield urethane, with no luck.
Since the urethane stays flexible, the latch is constantly being moved and pulls off.
I would suggest a plastic adhesive, you should be able to find a small kit at an auto parts store for a reasonable price. Maybe sand the glass and the "clip thingy" first with 40 or 80 grit.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 06-30-2009, 05:42 AM   #4
Blazer1970
Blazer1970's Avatar
Re: Adhesive's?
A really high quality 3M 2 sided tape might work for that.
Blazer1970 is offline   Reply With Quote
Old 06-30-2009, 01:57 PM   #5
Nova70
Nova70's Avatar
Re: Adhesive's?
I thought about that but I'm thinking the pressure when you latch it will pull it off like the others. Rear view mirror adhesive is stronger than super glue and it didn't hold it...
Old 06-30-2009, 06:37 PM   #6
mbgmike
Re: Adhesive's?
I am talking about a high quality urethane not the 3m crap for $14.00 at the parts store. We do it all the time and it holds. It won't move
they make all kinds of urethane with many recipes. You just have to use the correct one.
Old 06-30-2009, 06:39 PM   #7
mbgmike
Re: Adhesive's?
Not strong enough
Old 06-30-2009, 08:58 PM   #8
mycool72
mycool72's Avatar
Re: Adhesive's?
I riveted the one on my 88 would that work for your app?
mycool72 is offline   Reply With Quote
Old 07-01-2009, 12:20 AM   #9
Nova70
Nova70's Avatar
Re: Adhesive's?
It's glass though.. How would you rivet to glass?
Old 07-01-2009, 08:35 AM   #10
mycool72
mycool72's Avatar
Re: Adhesive's?
You can't...my 88 had a metal surround...well i'd say try the adhesive mentioned above.
