01-05-2003, 12:56 AM | #1 |
Recycler
old style oil filler
ok, I like the valve covers with out holes in them. I've got the two barrell intake that allows me to fill in the front. What would be a good, old style intake if I wanted to put on a 4 bbl?
72 C20 with a 350. Previous owner swapped the 4 speed for a 700R4 auto. I'm retired and volunteer at state and national parks. I spend summers in Oregon. Found this truck for $800 and offered $600. Paid for it with $$ made from recycling bottles and cans. Oregon pays .05 per can/bottle. Now doing restification with recycled parts purchased with recycling $$. |
01-05-2003, 01:05 AM | #2 |
Offenhauser 360 equa-flow..you can get it with or with out front oil tube and its a duel plane
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
01-05-2003, 01:49 AM | #3 |
If I'm not mistaken the Performer has the boss cast on it so you can drill or bore the hole to accept the filler tube.I think Weiands do also,or you could go to a swap meet and find some Offys and Holleys with the hole already there.HF
01-05-2003, 02:18 AM | #4 |
Another thought would be to use a stock one. It will work fine on a stock 283. There are plenty of older four barrel manifolds with oil filler tube on them, should be cheap. Just depends on what you want.
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
01-05-2003, 02:19 AM | #5 |
Jostrans68
or a older factory quad manifold .... I have one with a chrome oil tube
[CGTW Member former 67-72 now with a 96 silverado |
01-05-2003, 03:28 AM | #6 |
Recovering Truck Driver
I have a 4 jet intake off a 57 283, but it uses the really small square bore old school 4 jet rochester carb. I looked all around my area for a spread bore intake for my truck with the filler tube, no luck whatsoever, so I put the valve covers back on with the holes in them until I can get enough money together to get an aftermarket intake, but I also need of figure a way for the PCV valve, I refuse to cut my purdy corvette alluminum valve covers.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
