Old 06-29-2009, 10:21 PM   #1
nac593
what should voltage be WHILE CRANKING?
So if the battery shows 12v when truck is off, what should it be while cranking?
nac593 is offline   Reply With Quote
Old 06-29-2009, 11:27 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: what should voltage be WHILE CRANKING?
I don't like seeing it drop below ten, but the reality of it is... it can go low, as long as it starts, and it has enough amps to roll over at a decent pace.
Old 06-29-2009, 11:53 PM   #3
QKENUF4U
QKENUF4U's Avatar
10.5 is usually the limit and i personally wouldnt want it going much lower.
QKENUF4U is offline   Reply With Quote
Old 06-30-2009, 05:44 AM   #4
jim zag
ENGINE BUILDER
jim zag's Avatar
Crank it for 15 seconds and voltage should not go below 9.6.
JIM ZAG
jim zag is offline   Reply With Quote
Old 06-30-2009, 06:47 AM   #5
Andy4639
Old member
Andy4639's Avatar
If you have a TPI unit they say it needs to stay above 11 volts to crank. I know you have to cut the factory coil wire out and replace it with straight wire. The factory has a resistants built into it to drop the voltage.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
