Old 06-29-2009, 11:01 PM   #1
big blue 72
starting the engine without a stand?
I have my 250 six cylinder on a oak pallet that i have tied it to with chains. Could I hook it up to a gas can with a gravity feed to the fuel pump and crank it over or even run it for a short period of time safely?
I do have the starter hooked up and a jump starter /inverter for power,or a battery. No tranny mounted yet.
I'm just wondering .do i need to really brace this to the wall of the garage /fence posts, etc to test start it?
I can even hook up a three row radiator to it if i should?
As you can tell, i'm a plumber, not a mechanic and all the guys who usually help me are just busy this time of year ,but i wanna see if this engine will crank/run.
Any suggestions are welcome so i dont kill myself.
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
Unfinished Projects Club
Outdoor Sportsmens Club
big blue 72 is offline   Reply With Quote
Old 06-29-2009, 11:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: starting the engine without a stand?
I've seen it done before.
If you hook up a rad to it, then remove the fan. You could just use a piece of pipe and connect the upper and lower hose together and fill them (and the engine) with water. You'll only have it fired up for 5 min tops anyways.
Matter of fact.... just remove the fan period. No need if slinging the blades around, they'll do nothing but threaten life and limb.
I would strongly consider a brace on the passenger side, but if you can keep off the throttle all together, then it won't be needed, but the reality of it is, you may have to rev it to fire, or to maintain idle, or just becouse it is fun.
Make sure it is sitting verticly and no leaning, need to keep the oil pump pick up in the oil, and if it is leaning, it may not happen.
I would wire the ignition to a battery with a toggle, or a quick disconnect (alligator clip maybe) so you can shut it off instantly in case something goes wrong.
Hook battery cables up, one to starter, one to the block, then a remote starter button to the S terminal on the starter, then the wire going to the ignition (coil, or HEI) with the afomentioned quick shut off. Thats the wire you need to unplug to make the motor shut off.
Old 06-30-2009, 12:49 AM   #3
GruntMoanCough
GruntMoanCough's Avatar
Be sure to wear gloves, goggles, a flak jacket, stand back, and make sure the video camera is running, I gotta see this!
Just kidding, you'll probably survive.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 06-30-2009, 01:11 AM   #4
vectorit
What?
vectorit's Avatar
Make sure all flamables are far away, and don't use a container that has more fuel needed to do a quick fire up. Since there will be fire coming from the exhaust outlet, and that could catch things (your wooden stand) on fire.
If the engine falls over, or you get startled and knock something over you don't want a large amount of fuel to cause a catastrophe.
Be carefull.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-30-2009, 07:35 AM   #5
big blue 72
Good idea on the toggle switch Andy. I have to modify an old distributor to make my oil pump primer with tonight, then hopefully it wont rain when i'm ready to start. the next couple of days arent lookin good for this .
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
Old 06-30-2009, 09:59 AM   #6
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Do you have an engine stand? I fire all my motors on an engine stand. I have the C kind of stand and not the cheaper T. I made braces that run from the outside of the stand to the engine mounts. It works perfect and doesn't move. There is a link called "may I hear your motor/exhaust?" the first post is me firing a 460 BBC. It was smooth as silk.
prostreetC-10 is offline   Reply With Quote
Old 06-30-2009, 10:06 AM   #7
BarryB
BarryB's Avatar
I've never done this , but have watched my dad do it. He would pull a motor out of a junk car, then advertise it forsale, when potential buyers would by he would start it on the ground with out being strapped or anything.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 06-30-2009, 10:19 AM   #8
VanceH
Loving the Jimmster
VanceH's Avatar
If you do this please take a video!!! I would love to see that.
VanceH is offline   Reply With Quote
Old 06-30-2009, 02:13 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Right before you give it the gas, and if you find yourself saying to whoever is near, "Hey! Watch this!", you might want to rethink your plan.
Member Nr. 2770
Old 06-30-2009, 03:32 PM   #10
70 shorty
Where's my beer?
70 shorty's Avatar
Yup, famous redneck last words. Y'all aint gonna belive this $*it! And yeah you're right, it takes one to know one.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 06-30-2009, 03:55 PM   #11
big blue 72
Guess that means youins know I aint much of a gear head huh.
But, I'm tryin man ,I'm tryin!!!!!!!!!
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
Old 06-30-2009, 05:53 PM   #12
Josh
He's got mean nasty FANGS!
Josh's Avatar
Another member did it for me to show it running for an engine I'm picking up to go in my panel to get her back on the road.
Josh
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 06-30-2009, 08:57 PM   #13
big blue 72
Thank You Josh!
that is exactly what I am doing with the 250 I've got for my panel, except i dont have a HEI distributor yet.
Thanks again!
Broken Back Club
72 Club
GMC Club
Panel truck Club
6 cylinder Club
