Frame Rivets
so, after two years, i've finally got around to prepping the frame i got from LockDoc (removing manual trans crossmember, and installing C-Notches), and all these rivets are driving me absolutely batty...
basically i've been cutting a X in the head, and then using a hammer and chisel to break the pieces off... There has to be an easier way to accomplish this task... any suggestions?
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Active Member
Re: Frame Rivets
air chisel - should cut thru those puppy's in a big hurry
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
TOTY 2006
![]() Join Date: Dec 1999
Re: Frame Rivets
That is close to what I do. I drill the middle of the rivet head out, then a few taps with hammer/chisel to remove whats left of head, then hammer/punch to remove rivet.
#4 | |
I'M TRUCK CRAZY!
Re: Frame Rivets
after you put the X in it. Last edited by LOW DOUGH; 06-30-2009 at 04:03 PM. |
Under Construction
Re: Frame Rivets
i grind the head flush, then use a BFH and a punch
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
![]() Join Date: Oct 2006
Re: Frame Rivets
I agree I grind the head flush and then punch them out quick and easy
Spanky ![]() |
![]() Join Date: Sep 2007
Re: Frame Rivets
Take a BFH and a punch he says...
![]() A little closer... ![]() Oh, and here is my dog. ![]() I cut an X into mine, ground them off.. all of them... all of them... all of them... *sigh* Then punched them out. I replaced them with Grade 8 bolts, washers, lock washers and nuts. Good luck man, and where gloves like I should have. |
#8 | |
member #16
Re: Frame Rivets
That wont happen if you have the wife hold the punch. ![]()
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Re: Frame Rivets
and that is exactly why i'm divorced now....
she was tired of holding the punch ![]() seriously though, i've tried using my air chisel, but i don't think my compressor has the capacity nor cfm necessary. thanks for all the input, and if i never see another rivet it'll be too soon ![]()
I'M TRUCK CRAZY!
Re: Frame Rivets
try putting one more line in your X, then use the air chisel. I had to do that a couple of times.
member #16
Re: Frame Rivets
I drill about a 1/4" hole and whack it with a chisel and they pop off. also they punch out easy when you relieve them.
![]() Join Date: Feb 2008
Re: Frame Rivets
The best way I have found is to get a GOOD resin fiber disc and angle grinder to grind the heads completely off, somewhere around 24-36 grit. It only takes about 15-20 seconds to grind the entire head off with a good disc. I started off with x-cuts and an air chisel, but this was MUCH easier to do.
Then I used an air hammer with a punch to drive the rivets out. This works probably 90% of the time, but occasionally you'll need a monster hammer and punch to get some stubborn ones out instead of the air hammer.
1967 Chevy SWB 1972 Chevy SWB 1972 Chevy SWB K20 4x4 1991 Ford F-150 2013 Dodge Ram 1500 4x4 |
