Old 06-30-2009, 04:04 PM   #1
nac593
please help!! truck wont start
1969. new everything. new crate motor,hei dist., alttenator,battery....I have put 6000 miles on it since putting the truck together. Everything has been fine. Starts right up USUALLY....Yesterday morning I jumped in and went to start it. It was having a real hard time cranking. Voltmeter showed 8 volts while cranking. I thought the battery was bad so I had it checked at the store and they said it was ok. I charged it , put it in, tried to start it and same thing. 8 volts and struggling to crank. I went and bought a brand new battery and same thing. 8 volts while cranking and struggling. It only cranks a few seconds and the new battery already seems drained. I thought with a new battery it would crank fast but it still barely cranks. Everything has been fine since I put it together about 1 year ago. More info...altenator was showing 18 volts...I replaced the altenator and it showed about 14 volts...drove it about 2 days and then this happened.. PLEASE HELP!!!!!!
nac593 is offline   Reply With Quote
Old 06-30-2009, 04:10 PM   #2
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: please help!! truck wont start
I don't know.... Get your voltage regulator tested and your Starter. The auto parts store can do it. I'm just shooting in the wind here.
LOW DOUGH is offline   Reply With Quote
Old 06-30-2009, 04:11 PM   #3
69sixpackbee
Battery cables.
69sixpackbee is offline   Reply With Quote
Old 06-30-2009, 04:11 PM   #4
craig24671
craig24671's Avatar
Sounds like your starter might have went bad on you. I would take it off and have it checked
Spanky
craig24671 is offline   Reply With Quote
Old 06-30-2009, 04:47 PM   #5
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Yeah, Probably the Starter
Old 06-30-2009, 05:10 PM   #6
nac593
just took the starter out and had it checked. They said its fine. HELP!!!
Old 06-30-2009, 05:26 PM   #7
El Jay
Gone to greener pastures
Make sure the your cables & stuff are nice & clean & shiny. Use a battery brush to clean the cables (I know, it's a new battery) just to make sure you don't have any unnoticed corrosion on the battery.
Clean the inside of the cable ends with a battery brush.
Make sure the "+" cable is nice & clean at the solenoid & the solenoid is clean.
Ditto for where the ground cable attaches to the engine, Clean terminal & shiny block.....core support ground, engine to frame, frame to cab.
A poor electrical connection can genuinely make you crazy & do some weird stuff to vehicles.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-30-2009, 06:25 PM   #8
nac593
cleaned all cables. redid grounds. same thing. 8 volts when cranking.
Old 06-30-2009, 06:44 PM   #9
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Would you be able to replace it with a known "good" battery and try that? I needed a battery, went to Wallymart and before I left I asked the guy if he could test it just to be sure.....Nope that one is bad, go grab another......test......nope that one is bad too. Let's go to the rack and check a few out. 3rd battery off the rack was finally good. Why? I couldn't answer that other than it was Wallymart.
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 06-30-2009, 08:55 PM   #10
mycool72
mycool72's Avatar
Sounds like bad grounds or not enough of them.
mycool72 is offline   Reply With Quote
Old 06-30-2009, 08:58 PM   #11
tim21391
tim21391's Avatar
could it be the battery is too small?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-30-2009, 08:58 PM   #12
tim21391
tim21391's Avatar
i run a 950 cranking amp on my truck
Old 06-30-2009, 09:24 PM   #13
hilandr452
hilandr452's Avatar
If the distributor slipped or the timing chain slipped and the timing is retarded too much, there could be too much compression during the cranking before the spark is able to make happy piston love. Check your timing. Alternator or voltage regulator would not matter if the battery is fully charged and the starter is good. Could also be the starter isn't aligned properly with the flex plate or pressure plate. You may need to shim it up. That's all I got.
Dan
Dan Smith
Colorado Springs, CO
71 GMC Custom Camper "Longhorn" 454, TH400
73 Chevy Camper Special (Yes, it's badged a camper special) Flat Bed Motorhome conversion 454, standard tranny
"DON'T TREAD ON ME !!!"
My Project: http://www.picturetrail.com/sfx/album/view/20829244 , http://www.picturetrail.com/sfx/album/view/24654442
hilandr452 is offline   Reply With Quote
Old 06-30-2009, 09:33 PM   #14
americanmusc1e
americanmusc1e's Avatar
bad ground-check and clean connection on battery and motor
bad power connection-check and clean on battery and starter
bad starter-
bad battery-
bad battery cable-
ignition timing off (it made my motor hard to crank)-
valve timing off-
engine tight-you could try to turn the motor over with a 5/8 socket on the harmonic balancer and see if it's tight
not much else it could be!!!
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 06-30-2009, 10:09 PM   #15
nac593
thanks for the help so far guys. I'm going to keep working on it
Old 07-03-2009, 08:52 AM   #16
nac593
Got it!! It took a few days but got it started. Had voltage to dist., but no spark. Changed parts in dist. and started right up!! Thanks for all help.
Old 08-07-2009, 11:07 AM   #17
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
so, what did you replace in the dizzy? I had the same problem once. I ended up putting a new dizzy in and it fired right up. so, something inside it was bad.
Old 08-07-2009, 11:14 AM   #18
cdowns
cdowns's Avatar
BAD GROUNDS cable connections
