Compatibility
Looking at two 78 Suburban 2 wheel drives that both have a 454 and are currently running. My plan is to either drive one till it breaks down and then swap into my 69 when it's ready for engine and transmission or just park it and swap. What transmissions normally come with that year? What other parts besides those are worth keeping to transplant to the 69 if any?
![]() Join Date: Oct 2006
Re: Compatibility
Th trannys should be 400 turbos behind a big block.
its all about the +6 inches
Re: Compatibility
TH400.... I'm buying one too
Re: Compatibility
Have any of you done this pulling a 454/TH400 from a burb and into a 2 wheel drive truck? Aren't these motors meant for towing? What sort of things am I going to need to pay close attention to or is it pretty straight forward?
#5 | |
Re: Compatibility
As for the engine swap, a 454/th-400 would be no different that putting in a factory 396/402. As long as you have the correct mounts and brackets.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Re: Compatibility
unless there 3/4 ton... most big blck burbs ive seen are 3/4's but if its a 1/2 t then DO IT!
