Hut Oh, Uno Problemo' What to do in front of the carpet?
Heres a picture of the problem
After installing the Dynamat along the backwall, floor, and firewall. I opened the box with the new carpet in there and set it in to see how it looked. ![]() ********Now, what to do with the area in front of the carpet where you can still see the Dynamat?********
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build Last edited by Sinisterspeed; 06-30-2009 at 11:37 PM. |
My Carbon Footprint
Re: Hut Oh, Uno Problemo' What to do in front of the carpet?
Won't the heater box cover a good portion of that in the center?
I don't think that carpet is right - they should go a little further up. But I agree, the heater box will hide the middle there.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 Last edited by dan42; 06-30-2009 at 11:40 PM. |
This truck has no heater box. (vintage air set up later)
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
Any other ideas?
People know me
PAint it?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
What?
Yea, I think I'd spray the exposed dynamat with some flat black.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
My Carbon Footprint
but won't that stuff flex even a little. Seems he would have paint flakes going everywhere. Passenger and driver's feet might scuff it easy too. You might be better to try and color and texture match some fabric or carpet or something to make it look sanitary. That is a quick eye catcher so if you don't do it right.....just that little area can ruin an otherwise nice interior. Is there anyway to leave less under the seat and scoot it up???
My Carbon Footprint
Ah ha!!! I know what it is or what will fix it. I had to go and look at mine and it stops at about the same place. It looks like you are missing or could get this black factory cardboard piece that covers that up all the way under they dash. Hopefully you can see mine from the pic. It's definately original and I'm sure you could get it aftermarket!
#10 | |||
Thanks for the great ideas... This was deffinatly not something I had thought of when I decided to put it together without a heater for now.
Laid Lo
Buy some marine type carpet or the felt type they use to cover speaker boxes. It won't fray on the edges and doesn't have a backing like the carpet in the repro kits.
Trim it how you want it to fit, give a couple inches for it to underlap. Spray down some adhesive (I like 3M's Super 77) and lay down the carpet. Place new carpet over it.
Semper Fi, Jeff ![]() '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
#12 | |
Retired Air Force Veteran
![]() Join Date: Aug 2007
http://www.lmctruck.com/icatalog/cb/full.aspx?page=42
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 07-01-2009 at 06:12 AM. |
#13 |
a roll of cheap black carpet from walmart is like 10 bucks. like blime81 said just glue it down
1966 Chevrolet Suburban 1955 Chevrolet Bel Air |
#14 |
Its Topless Season!!!!
I agree....but instead of putting it up front...I would put it under the seats and move up the gray carpet...just an idea..
#15 |
Maybe the folks who sold you the carpet can sell you a piece of scrap big enough. If not, maybe they sell door inserts or mats. You could cut a mat to fit...
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
#16 | |
Fat Fendered Fleetside
The stuff you are looking for is called Ozite. not sure of the spelling, but if you got to one of your local upholstery shops they will know what you are looking for. It stretches nicely, so you can get it to lay smooth in the corners and flat in the flat areas. Only thing is I wouldn't use 3m spray glue. The heat from the firewall area alone could be enough to release the carpet. Get some HHR(high heat resistance) contact cement. Maybe the upholstery place will sell you some, if not the DAP weldwood in the red can is a good second choice. Follow the directions on the can, and don't push the carpet down hard until you are sure that's where you want it to be. Then you can lay your molded carpet over it. presto, new carpet all the way up the firewall!
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
#17 |
Loving the Jimmster
When i bought my carpet kit it came with a piece i am assumming is for the gas tank. With the gas tank gone one could use it for the fire wall i would think?
#18 |
These are some great ideas.. Thanks guys! this site is the best!!
#19 |
#20 |
The Older Generation
The firewall insulation covers that area. There aren't any cutouts in the insulation for the heater but they have two areas marked that you can cut out for the heater mounting bracket. All you have to do is leave those places intact and it will be pretty smooth. LockDoc
#21 | |
#22 | |
I have purchased 3 of them. I bought them from Art's Classic Truck Parts in Indianola, IA. Some of the stuff you mentioned will have holes already cut out because all of the stock trucks need those areas cut out. If you filled the original holes for the insulation pad retainers on the firewall I'm not sure how you will fasten it up. Even if you purchase parts from the same vendor there is no guarantee they will be from the same manufacturer. I have run into that a lot lately... ![]() LockDoc
#23 |
That's right, it's Copper!!
I had the same problem. I used a piece of black vinyl, glued it down with 3M super 77
Tom: ![]() 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
