Old 07-01-2009, 05:41 AM   #1
anythingonwhlz
Need 1970 Blazer 2wd swap advise
I have a 1970 Chevy K5 4x4 and would like to remove the 4x4 front suspension and axle to replace w/ 73-87 1/2t Chevy 2wd suspension. I know I have to remove and replace the front cross members but not to sure how to line up and install the 2wd crossmember for a perfect fit and alignment. Any advise is greatly appreciated
anythingonwhlz is offline   Reply With Quote
Old 07-01-2009, 07:57 AM   #2
nightmare
nightmare's Avatar
Re: Need 1970 Blazer 2wd swap advise
welcome to the board.
lots of people have done this conversion, just look in the Builds sub-forum. to answer though, there should be several holes in the frame where the crossmember would line up. there will be 2 holes that you will have to elongate in the frame to accommodate the new crossmember. good luck with it, and post some pics when you get a chance.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 07-01-2009, 08:49 AM   #3
TonyJohnson
TonyJohnson's Avatar
If you have to deal with a different drive shaft, I'd use the opportunity to move the engine a little forward in the engine bay.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 07-01-2009, 09:22 AM   #4
hotrodhomi
hotrodhomi's Avatar
I have not done this, but I've read that the 2wd crossmember will bolt right up with the exception of 2 holes that will need to be drilled.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 07-03-2009, 03:34 PM   #5
AKoldstyle
AKoldstyle's Avatar
I just did this conversion and found the rear 2 outside frame holes line up then I had to drill the other 10 holes.my build is prostreet/dragrace blazer and has some pics of this. Good luck and this is fairly straight foward.I have lots of pics and time if you need a answer or advice.
AKoldstyle is offline   Reply With Quote
Old 07-03-2009, 11:46 PM   #6
anythingonwhlz
what 2 outside frame holes are you referring to?
Old 07-04-2009, 12:17 PM   #7
capev86
is the 73+ front cross member identical to the 67-72 units? swapping the setup into a 50's gm you have to narrow the crossmember to get the correct track width and line up with the frame rails. comparing my 72 burb to my dad's 87 burb 2wd it looks almost the same even though my truck is a 3/4 ton.
capev86 is offline   Reply With Quote
