Between Trucks...
Need pics of underbed spare tire mount
Just ordered spare tire mount parts and need pics of one installed under the bed.
Or if somebody has an Assembly Manual, a pic from that would be a big help. Thanks.
Beat it to fit, Paint it to match... ![]() |
Re: Need pics of underbed spare tire mount
It's not real great, but here is an exploded view from LMC
http://www.lmctruck.com/icatalog/cb/full.aspx?page=36 |
Between Trucks...
Thanks, have the catalog, and actually ordered the parts from them. I need to know how the top brackets attach to the frame.
It's not too clear in the catalog pic. Edit: Nevermind I think I figured it out.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 07-01-2009 at 11:42 AM. |
Under Construction
post pics of the install
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
Between Trucks...
It seems pretty straight forward, I think anyway. Bolt the brackets to the cross strap, two bolts to bolt the cross strap to the frame. Just gotta figure out which holes in the frame to use.
Never Ending Projects
Not sure if this helps. This is a long bed frame.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Between Trucks...
Thanks for the pic Mike. Doesn't help, but thanks all the same.
Between Trucks...
Got it installed. Ended up not using the $20 dollar bolt from LMC on the passenger side, because there's no way to get it into the frame with the bed on. I ended up using some threaded rod. Could probaly do the same for the driver's side and save another $16. Nice to get the spare out of the bed.
Beat it to fit, Paint it to match... ![]() Last edited by Sinister; 07-09-2009 at 06:12 PM. |
