Old 07-01-2009, 12:21 PM   #1
JesseSimon
Asks alot of questions
JesseSimon's Avatar
Frame swap question, please help
Ive got a 66 and I want to swap to disc brakes 5 lug, will the cab and bed bolt up to a 72 frame or will modification be necessary? I found a killer deal on a 72 frame with 5 bolt suspension and brakes
MY STABLE:
'66 C10 LWB turning it into a shortbed stepside
'77 LWB (my daily driver).....oh its a FORD ahhhhh!
'07 MAZDA 3 (the wife's ride)
JesseSimon is offline   Reply With Quote
Old 07-01-2009, 12:25 PM   #2
joe231
joe231's Avatar
Re: Frame swap question, please help
all you need to do is bolt up the suspension(control arms out) from the '72 to your '66 frame.
if you want power steering, you will need an adapter kit. Captianfab on here sells them as does most of the vendors for these trucks.
Does the '72 have coils springs in the rear? if so the axle is a bolt in swap.
I don't believe the frame mounts will interchange between these years, and if your frame is good it will be less work to do the suspension swapping
CHEVY ONLY
Old 07-01-2009, 12:27 PM   #3
JesseSimon
JesseSimon's Avatar
The frame is a leaf rear, not coil, can it still be done? Take some welding I guess?
MY STABLE:
Old 07-01-2009, 12:33 PM   #4
joe231
joe231's Avatar
the '72 is leaf and the '66 is coils?
you can buy conversion perches from CPP that are welded to which ever axle you wanna use....
the '72 differential is 1 1/2 inches wider than the '66. you can but 5 lug axles that will fit your '66 differential, or even have the 5 on 5 pattern drilled in your 6 lug axles.....
another thing is if you get the suspension from the '73-'87 1/2 ton trucks and '73-'91 1/2 ton subs they have rubber control arm bushings and less expensive parts (ball-joints, ect.)
CHEVY ONLY
Old 07-01-2009, 12:38 PM   #5
JesseSimon
JesseSimon's Avatar
Good point on the 73-87. Also I did not know about the width difference. There is a guy out in Oklahoma selling a 72 SWB frame with the rear end and front suspension, asking 250, thought I could haggle a bit and get a good buy on it. Sounds like a solid deal for anyone wanting a SWB frame though....I think Im gonna pass on it and look elsewhere for parts if anyone wants this guys number let me know
MY STABLE:
Old 07-01-2009, 03:18 PM   #6
joe231
joe231's Avatar
good call, around here you can find the whole cross-member from a salvage for under $150, or find a junk truck for cheap.
keep an eye on craigslist.
Here is a crossmember for free...it is a ways from you though
http://oklahomacity.craigslist.org/pts/1249006179.html
CHEVY ONLY
