Old 07-01-2009, 12:30 PM   #1
strick9c10
In truck cam swap
Hey peeps -
I looked through several posts on the site, but either couldn't find the info I needed, or didn't have the correct key words...
Has anyone done a cam swap with the engine still in the truck? I've seen this done before in magazines, but it always showed just one picture of the people installing the cam & a small blurb that accompanied it. No meat & potatoes.
I'm going to be installing a new intake, carb, heads & valve covers anyways, so I figured what the heck. I also realize I'll have to remove the radiator and other front engine components. I just don't feel like lifting the whole thing out.
Tips, tricks, detailed info & especially pics would be a huge help!
Thanks as always!
strick9c10 is offline   Reply With Quote
Old 07-01-2009, 12:35 PM   #2
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Re: In truck cam swap
You would replace it just as if the motor was out, you just need to remove the radiator, grill, etc. Pretty easy job.
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 07-01-2009, 01:39 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Drop the front of the oil pan before you install the timing cover. It makes ensuring the timing cover seal gets installed correctly light years easier.
But if you are going to tear it down to that point, life would be MUCH easier if you just pulled it. By that point, it would probably only take another 15 minutes to have it out.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-01-2009, 01:44 PM   #4
swb85
On a budget like Fred Sanford
swb85's Avatar
I've swapped cams with the motor in the truck. Have to remove the radiator and a/c condenser (if you have a/c). On my '85, I had to cut/bend a piece of steel bracing in the center of the core support to allow enough room for the cam to come out. Just welded that brace back up after the swap. IMO, a cam swap in the truck is easier/faster than pulling the whole drivetrain.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-01-2009, 02:03 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
here's step by step instructions
http://73-87.com/7387garage/drivetrain/cam.htm
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-01-2009, 02:25 PM   #6
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Core support gets in the way of the cam coming all the way out. 81-87 not sure about older ones.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-01-2009, 05:35 PM   #7
454HO
I did a cam swap a few weekends ago with the engine in the truck. I went ahead and removed the whole core support, but then I was getting ready to swap the whole front clip anyway. It's a little extra work, but it gives you complete access.
If you don't remove the core support, there is a vertical brace as swb85 says that you would need to cut and bend out of the way.
- Greg
454HO is offline   Reply With Quote
Old 07-01-2009, 11:07 PM   #8
pig rig
pig rig's Avatar
I have almost the same picture from a month ago
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 07-02-2009, 01:30 AM   #9
05Gibbs
05Gibbs's Avatar
i always do it in the truck i have the center part of my core support cut out and i just did some modding on my timing cover so pan removal is not needed
05Gibbs is offline   Reply With Quote
Old 07-02-2009, 07:04 AM   #10
strick9c10
Thanks for the info, links & pics! You guys are great!
I noticed on the step-by-step instructions link that flamingbig10 provided as well as the other pics and postings that removing the whole core support (or cutting/bending the piece of steel bracing in the center of the core support) is necessary for 81 and up trucks. No one seemed too sure about 73-80 trucks.
My truck is currently being painted, so it's not here. However, the guy who's doing the work said this would be a good time to do those mods. He just doesn't want a whole engine / tranny removal thing going on in his shop... can't blame him really.
Any info from 73-80 owners would also be great.
Have a great 4th!
Old 07-03-2009, 10:21 AM   #11
glock35ipsc
Swap your cam often, do you?
Bob
