Old 07-01-2009, 01:38 PM   #1
rome704
rome704's Avatar
need opinions on keeping my 350 tranny or switching
Well when i bought ((boomer)) the truck it had a 350ci/350 transmission with a Hurst shifter...it shifts fine but i need more gears on the highway its screaming and the revs are to high it really isn't that good on gas either even with the stock street gears...Maybe a 700r4 or th400 would be better? can i get some help
--Rome
Roman "LCPL" Planter
The Few The Proud The Marines
rome704 is offline   Reply With Quote
Old 07-01-2009, 02:40 PM   #2
rome704
rome704's Avatar
Re: need opinions on keeping my 350 tranny or switching
ttt
Old 07-01-2009, 02:54 PM   #3
Orange77
Orange77's Avatar
if your on the highway a lot then a 700r4 would be great considering it has the overdrive as well. They told me to do the same that it would swap right in. you'd only need to reroute some lines.
Orange77 is offline   Reply With Quote
Old 07-01-2009, 03:23 PM   #4
asphaltburner
asphaltburner's Avatar
Yo!
700R4. The TH350 and TH400 will give you essentially the same gearing,...the TH400 is heavier duty.
The 700R4 is an overdrive tranny and will lower your final gear ratio to reduce your rpms at highway speed. Search this, and the driveline forums for more info, but I believe it is a direct swap with the TH350.
Have fun! Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 07-01-2009, 03:23 PM   #5
rome704
rome704's Avatar
Thanks well it looks like im looking for a 700r4 then
Old 07-01-2009, 03:45 PM   #6
JohnC
JohnC's Avatar
Yeah for what it sounds like you are wanting I would go with the 700R4. That is the one I am switching my TH350 out for.
JohnC is offline   Reply With Quote
Old 07-01-2009, 03:50 PM   #7
rome704
rome704's Avatar
700r4 it is then thanks peeps
Old 07-02-2009, 01:49 AM   #8
rome704
rome704's Avatar
what car/truck donor would be best to get a 700 r4 off of
Old 07-02-2009, 04:10 AM   #9
79 silverado
I'm going to assume you are a 2wd... In that case, you have tons of options...
* full size chevy/gmc trucks
* full size/mid size gm cars like the caprice, impala, etc (careful, some are 200-4r series)
* camaro/firebird v8 only (the v6 had a different bellhousing pattern)
* corvette
the list goes on and on.
The trick is, try to find one from the later 80s or beyond. The earlier 700r4 trannies were not *as* strong and are more prone to wearing out earlier due to some design flaws that were compensated for in the later models... It can be corrected in a rebuild so if you are just looking for a core its not as instrumental, but, if its a slap in and go situation look for the later years...
79 silverado is offline   Reply With Quote
Old 07-02-2009, 10:05 AM   #10
larrystone
larrystone's Avatar
If you a just using the truck as a car and not a work truck hauling a trailer, I would suggest that you just swap the entire rear axle with one from a salvage yard that has a 2.73 or 3.08 ratio.
1992 C1500 WT LWB 4.3TBI 700r4 4.10 limited slip= Work Truck
1986 C10 Custom Deluxe LWB 4.3-4V TH350C 2.73 ac cruise tilt= Cowboy Cadillac
larrystone is offline   Reply With Quote
Old 07-02-2009, 10:20 AM   #11
rigon4
rigon4's Avatar
GM changed the 700r4 a little bit in late 87 and they are much better so look for some thing 1988 to 1992 for your swap
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 07-02-2009, 12:30 PM   #12
rome704
rome704's Avatar
* corvette
Yeah I'm 2wd Thanks for the List i wasn't sure so ill look for one out of something 80 or higher shouldn't b hard...
Yeah wont be pulling or hauling nothing well there is that mustang im getting soon but that's it...i wanted a higher posi ratio for the rear... What ratio is already in there...Isnt stock 2.73?...
will i have to changed the flywheel... and is there a stall you all could recommend?....Is the 700r4 longer? will i need a drive shaft? Just Curious
Old 07-02-2009, 03:57 PM   #13
rigon4
rigon4's Avatar
will i have to changed the flywheel... and is there a stall you all could recommend?....Is the 700r4 longer? will i need a drive shaft? Just Curious [/QUOTE]
For your ratio in the rear end look at your glove box sticker it could be anything
Your flexplate should be good.
A 9 inch tail shaft th350 is a 1/8 inch shorter than a 700r4
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 07-03-2009, 12:50 PM   #14
rome704
rome704's Avatar
thanks bro new shaft as well
Yall have been alot of help
Old 07-03-2009, 05:34 PM   #15
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
700r4. You'll have overdrive for the highway and a better 1st gear for acceleration. The later ones have a aux valve body. Some minor adjustments were made by GM like when going from P to R or D it doesnt jerk.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 07-03-2009, 08:38 PM   #16
boatpuller
boatpuller's Avatar
i run a th350 and turn a little over 2 grand with 3.08 rear.and a little taller than stock tire.personally i like the th350.the other's do have o.d's which help.check you rear end ratio.it may be low.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 07-03-2009, 11:40 PM   #17
rome704
rome704's Avatar
i have no idea where to look i dont see anything thing about the rear ratio
anyone else has a 78 swb
Old 07-04-2009, 08:41 PM   #18
benoit454
Chris
benoit454's Avatar
ther'es a sticker in the glove box with axle ratio on it or under hood on the fender well driver's side. Or you can pull the cover.
I personally hate 700r4's because if the tv cable aint right it'll be sloppy or burn up quickly. It seems to lack power IMO also. I never liked them.
I run th350's in everything and love em. Now the short tail th350 is shorter then a 700r4 so you'd need a driveshaft shortened or find a shorter one. Flexplates should be the same.
I'd run another rear end in it, one that's more highway geared like the one in our 84 it sucks it's a 273 and I hate it for take off. If you were closer I'd trade ya lol. I want a taller gear something for more take off and you want less gear for highway and less rpms.
You can also run taller tires, that brings the ratio into were you want it more.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 07-04-2009, 09:30 PM   #19
rome704
rome704's Avatar
Thanks for the Input
Old 07-04-2009, 11:08 PM   #20
silvereagle07
silvereagle07's Avatar
You can also get the transmission from aftermarket trans shops like this site.
http://www.bowtieoverdrives.com/index.shtml
They also have good info on the site for the overdrives and tv adjustment.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
