454 MAKES IT ROAR
Driveshaft. First major breakdown.
Today while overtaking at speed a real bad noise started coming from under the truck, I hit the brakes right away, and started to head for the side of the road the noise got worse crashing and banging and what sounded like metal draging along the road then something bounced out from under the truck and landed in the slow lane...Yes it was the rear half of my driveshaft, it had broke out of the u-joint straps on the rear end...why or how? I have no idea.
Classic parts has new u-joints and straps, but i'll have to post a WTB in the parts for sale for another drive shaft as this ones a bit banged up. ![]() ![]() ![]() ![]()
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
Re: Driveshaft. First major breakdown.
YIKES.......don't have a clue what caused it but hope you had no other
damage. looks like one of the u-joint caps seized and gave up. maybe it happened cuz you and all the other drivers were driving on the wrong side of the road....... ![]() ![]() ![]()
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
454 MAKES IT ROAR
![]() Join Date: Dec 2006
That happened to me a million years ago and I think I had to replace the companion flange in back there too because it got a little bent. Can't remember the cause. I think on mine the pinion angle was WAY to steep and the u-joint eventually fell apart,lost all the needles and then did what yours did.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
Nothing to see here.....
![]() Join Date: Jun 2007
look at the bright side Nigel, that big block had probably been twisting hard on those old, stock u-joints for a while now. you were more than likely going to need them replaced sooner than later. at least the drive shaft didn't kick up through the bed floor or you DIDN'T HAVE A WRECK!!
I'm sure someone will have a good used drive shaft for you here. I'm just wondering how much a drive shaft build at a custom shop in the UK would be as opposed to getting one from here in the States then having it shipped? good luck, Mate!!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
#6 | ||
454 MAKES IT ROAR
Nigel,
you should give the drive shaft shop a try though. take in what you have. you never know, yours might be okay with a good balance.... unless it's trashed beyond balance. when workinglonghorn is talking about pinion angle he talkng about the theoretical centerline through the rear axle to the drive shaft centerline. example: when you lower the rear of a truck, the pinion angle changes to the point that you may need to put insert a 2 degree wedge between the axle and the control bars. this allows the rear u-joint to run at the proper angle. since your truck hasn't been lowered much, you shouldn't have a problem with the pinion angle.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 07-01-2009 at 09:22 PM. |
![]() Join Date: Dec 2008
A driveshaft is a driveshaft, I bet they can fix you all up on that side of the pond...if not, I will donate a driveshaft to keep you going, you pay to ship and tell me where to send it.
That's why drag cars have drive shaft loops. It can go very wrong...
Back 20 years ago I was driving my '62 International pickup down the highway when the driver-side front wheel decided to shear off at the hub. I was going about 55 or so and the hub dug into the asphalt and the truck literally stood up on its nose, sliding 25 feet with me suspended above the steering wheel, crapping my pants. It finally made it to a point where the rear fell back down and the thing stopped, but it left a huge trench the entire way across two lanes to the shoulder. I walked away from that truck and never looked back. lol. It might still be sitting there....
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
Yeah,what tbc-1 said about the pinion angle. On mine,it wasn't a matter of lowering or raiseing the truck ,but what happened was the diff housing rotated on the axle tubes so that the conpanion flange (the one in the back that the driveshaft is attached to) was pointed way up,which puts lots of strain on the u-joint.
The u-joints are made with small roller-bearings,sonetimes called "needle bearings". When these needles fall out there is lots of slop and it will eventually fall apart. That's what happened to mine,but I didn't have a 454 either! Just a very high torque 350 extreme RV cam. Did you notice any strange clunks or other noise or vibration before the failure?
Ok, that's some funny stuff! I needed that!
#12 | |||
454 MAKES IT ROAR
It seems there is a guy here who will have a look at my driveshaft, he works on commercial vehicles though, and he did say that as it was American that his adapter plates (whatever they are) will probably not fit mine when it comes to balancing it. It was funny when I rang him to explain....I was talking to him and refering to my "Driveshaft" when he then stopped me and said "do you mean Propshaft" (that's how it is refered to over here)oh yes I said I forgot I was British ![]()
#13 |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
I would ditch those style of u-joint caps and get the actual threaded strap type (with nuts of course). The type that you have are notorious for failure. This is the style:
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
#14 |
454 MAKES IT ROAR
Breeh, I never knew there was a different type available...who has them?
#15 |
You can get them from Jegs, Summit, or in the US at an auto parts store. Drivetrain shops usually have them as well.
#16 |
the boat guy
i dont think it would be worth the trouble of having a free shaft shipped to you when you would still have to take it to a driveshaft shop to have it ballanced as an assembly anyways. take in your old shaft, see if they can reuse any of the old parts such as the weld yokes or slip yoke. now is a good time to get the front shaft checked out also u-joints and carrier bearing.
i would stay with the strap style u-joint retainers, as u-bolts are easily overtightened causing premature u-joint failure and you would have to drill out the threads in your pinion yoke to be able to use them anyways.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#17 | |
454 MAKES IT ROAR
I understand were your coming from Brad, the only thing thats worrying me is the condition of the end of the D/S where the u-joint is, it is quite bashed up and I may not be able to fit a new clip to hold the replacement u-joint & bearing. Your right on the u-bolt question I had not noticed till I looked closer that the u-bolts won't work unless I drill out the bolt holes on my pinion. I have another question if anyone can answer.....do I need to buy specific u-joints that are compatible with a BB454 &TH400????? Also I had not realized till today that one of the tabs on the pinion yoke has sheared off so now I need to buy a new pinion....... ![]()
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 07-06-2009 at 09:48 AM. Reason: Info added |
#18 |
Grandpa in the rustmobile...
dayumn
my u joint broke and the driveshaft was still ok for draggin the asphalt 50 ft lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#19 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
My suggestion would be (if you cannot get yours fixed) is to find one in the states. Have whoever you get one from send it to a reputible driveline shop here in the states and have it completely rebuilt, ballanced, and new carrier bearing installed. There are many reasons to do this. First off witch you are in the United Kingdom so anything sent wrong like the front end of a driveshaft that has not been ballanced with the rear of yours will be a waste of shipping dollars and a good amount of time. Secondly, if the splines in the driveshaft are worn out or close to it, the driveshaft will vibrate and you will have to rebuild it anyway. (again you are across the pond so shipping dollars and time a huge factor there.) Also have them send you a new set of straps to bolt the driveshaft back to the rear end. (because) Unless you drill out the rear end yoke for the "U" bolt style straps, or replace the rear end yoke with one that accepts them you won't be able to use them. If you replace the rear end yoke, be sure to have them send you a new pinion seal. Also make sure that if you replace the yoke, that the pinion bolt is put back exactly where it was when you started. If not your rear end will be short lived and you will find yourself needing to rebuild it also. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
