Old 07-01-2009, 08:53 PM   #1
ol'blu72
Too much oil pressure?
Did a lot of work on the old girl this week. On my neighbors recomendation I installed a high volume oil pump while I had my pan off. Now I have too much oil pressure. Is this bad? What could happen with too much press and how likley is it to happen. It is at the top of the guage at idle Either way I can't fix it for a while the wife is done with me working on the truck. Am I going to blow somthing up? Cause I am gonna drive her.
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
Old 07-01-2009, 09:22 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Re: Too much oil pressure?
I think with a high volume pump and a stock pan you might suck the pan dry if you really get on it hard. I might be wrong, but I'm pretty sure I've heard that before.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-01-2009, 09:29 PM   #3
ll____b0t____ll
ll____b0t____ll's Avatar
Ide start by getting a oil pressure gauge thats full sweep and seeing exactly what numbers your hitting .
My 400 sb ran a high volume pump and stock pan and never had a that problem but 50lb pressure was about as low as it went and it would idle at around 75lb until warm I always kept it under 82 lbs.
ll____b0t____ll is offline   Reply With Quote
Old 07-01-2009, 09:35 PM   #4
GruntMoanCough
GruntMoanCough's Avatar
Just a thought (rare, I know), don't those high volume pumps come with 2 different pressure springs? (wait..... that's a question)
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 07-01-2009, 10:28 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Okay, for each 1000 RPM's, you need 10 lbs of pressure. Now, my school bus will be sitting at almost 0PSI at an idle. That is a worrisome thing, for me. However, I've been told that it has a high volume, low pressure oil pump. I reckon that's a good thing, because I have over 70K miles on it w/o any oiling problems.
Member Nr. 2770
Old 07-02-2009, 12:01 AM   #6
Sammy
I can't see how with a high volume oil pump you would starve it on oil. All the oil is running thru the engine. Now if you were doing serious stock car stuff, or drag racing, then you would add a larger oil pan capacity. Just can't see anyone on the street doing damage with a high volume pump on a street machine even under extreme conditions.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-02-2009, 01:48 AM   #7
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I'm with you on this one, there is only so much oil that the passages can hold...the faster you put it in, the faster it runs into the pan.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 07-02-2009, 05:49 AM   #8
ol'blu72
So do I have anything to worry about. What oil press are you guys running? any problems?
Brad
Old 07-02-2009, 07:36 AM   #9
gator2511
gator2511's Avatar
I've been running a high pressure pump with a stock pan for two years now with no problems.
gator2511 is offline   Reply With Quote
Old 07-02-2009, 08:02 AM   #10
Jim_PA
When I fire mine up, it idles at the "red line" of the oil pressure gauge for a while. After driving for a while, it will settle down at idle to about the half-way point.
Jim_PA is offline   Reply With Quote
Old 07-02-2009, 08:14 AM   #11
ol'blu72
What kind of pressures are you getting?
Brad
