Old 07-02-2009, 12:28 AM   #1
MisterE72
Keep Your Nose Clean
K5 blazer to 2WD frame
This has probably been asked before: Will a 72 K5 blazer body bolt right up to a 2WD 72 C10 SWB frame? If not what mods need to be made? Has anyone on the board done this? I've seen a Blazer converted to 2WD, but not a frame swap.
MisterE72 is offline   Reply With Quote
Old 07-02-2009, 01:21 AM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: K5 blazer to 2WD frame
Nope, the Blazer wheelbase is shorter (I think 11 or 14 inches) than the SWB. Also the hump over the rear axle is higher on the Blazer.
I suppose you could splice the front of the Blazer frame to the rear of the SWB frame.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 07-02-2009, 09:26 AM   #3
turp mcspray
turp mcspray's Avatar
A friend of mine did this to build a 2wd blazer. He had to shorten the frame and add the blazer specific body to frame mounts to the frame.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 07-02-2009, 12:48 PM   #4
MisterE72
I was hoping it wouldn't be too difficult. When I finish this truck I would like to get a blazer. But it seems like the 2WD are much harder to find than 4WD. We'll see what happens between now and then.
Old 07-02-2009, 01:15 PM   #5
turp mcspray
I would like to do this someday as well. I am going to swap in the suspension and make some perches for the rear coils. For me this will be the easiest route to take.
Turp Mcspray
