Old 07-02-2009, 08:34 AM   #1
TomsCheyenne
Fender repair............
Can anyone tell me where I can get a patch panel? Mine was ruined by battery acid rust, along with the radiator support.
See attached photos
TomsCheyenne is offline   Reply With Quote
Old 07-02-2009, 08:41 AM   #2
twotrucks
Junior Member
Re: Fender repair............
They make a patch panel for this. Check with any of the vendors that support the board.
twotrucks is offline   Reply With Quote
Old 07-02-2009, 11:07 AM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
this is a common issue, I have the same rust on mine (not quite as bad). you can get patch panels out of lmc or many others. good luck
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 07-02-2009, 11:08 AM   #4
TomsCheyenne
Thank you, which section do I look? I have been through the parts for sale section, where are the vendors listed?
Old 07-02-2009, 11:11 AM   #5
TomsCheyenne
LMC only has the back, I just checked my catologue.
Old 07-02-2009, 12:14 PM   #6
john
member #16
john's Avatar
Wes at classic heartbeat has them.
http://www.classicheartbeat.com/cata...nder%20tip.htm
http://www.classicheartbeat.com/Patch%20Panels.htm
john is offline   Reply With Quote
Old 07-02-2009, 12:47 PM   #7
TomsCheyenne
Excellent, thanks!!!!!!!!
Old 07-02-2009, 06:53 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You wont find a used one.If you do it will be attached to a fender and they will want to sell you the whole thing.That area is so prone to rusting i don't remember ever seeing one that was good unless the whole truck had been redone or was so cherry it was a true survivor.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-02-2009, 07:54 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Please take a moment and look over the rules you agreed to upon joining the site.
http://67-72chevytrucks.com/vboard/a...nt.php?f=3&a=9
The reason you weren't able to post in the parts forum is becouse you are not a subscribed member.
For subscribing info,
http://67-72chevytrucks.com/vboard/a...t.php?f=3&a=17
I modified your post instead of deleting it all together.
Old 07-02-2009, 10:16 PM   #10
BarryB
BarryB's Avatar
I have one that came with my project truck, It actually replaces the whole bottom of the fender. inner and out fender bucket.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-02-2009, 11:00 PM   #11
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Wink Re: Fender repair............
I will give you a HEADS UP on the fender patch ,
THEY ARE TO SHORT , unless they have made a major change the patch is 1'' to 1'' & 1/2 short , I did mine by adding a piece of metal to it but it caused more bodywork to have to be done ,
A GREAT WAY I THOUGHT OF LATER IS AS FOLLOW's
#1 ORDER TWO OF THEM !
#2 CUT THE TWO LEAVING EXTRA METAL
#3 FIT THE EXTRA LONG PIECES TOGETHER AND YOU WILL ONLY HAVE ONE WELD SEAM
this is the best and most effective way to do this ,, unless someone could tell WHOEVER IN THE CRAP IT IS THAT MAKES THEM TO SHORT ! THAT
HEY BUDDY THE ARE TOO DANG SHORT !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 07-02-2009, 11:08 PM   #12
19673ontree
CAN'T FIX NOTHIN
Arrow Re: Fender repair............
here is a pic from when I was working on mine , you can see in the pic how much to short the fender patch was ,,
underdash AC
Old 07-03-2009, 12:04 AM   #13
67ChevyRedneck
67ChevyRedneck's Avatar
The good truck parts come from California...
(They're true 67 fenders too!)
They're the most rust free set of original fenders I've ever laid my eyes on.
(And hells no they're NOT for sale!)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-04-2009, 09:17 AM   #14
ebfabman
Wes has a write up on how to do this repair. Here is the link
http://www.classicheartbeat.com/fender_tip_repair.htm
Hope it helps....eb
ebfabman is offline   Reply With Quote
Old 07-04-2009, 10:33 AM   #15
jd4300fel
jd4300fel's Avatar
i did mine not to long ago, I did just like the article on GMC pauls web site
I also had to remove the back piece the curve was not correct,then i had to make a pie cut down the front to get the inside front edges to line up i am going to run a bumper this wont be seen.
Mike K
Friend of Bill W
jd4300fel is offline   Reply With Quote
