Old 07-02-2009, 09:28 AM   #1
chris71
chris71's Avatar
rear-end perch differences?
Is there any difference in the angle of the perch for the ladder bars on a rear end between a shortbed and a long bed for a coild spring truck? same year truck in my case its a 71. i.e. did the factory weld on the perches at a slightly different angle for the shortbeds vs. the longbeds to adjust for the difference in pinion angle since the wheelbase is shorter on a shortbed? Thanks.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 07-02-2009, 11:09 AM   #2
BigCarl
Re: rear-end perch differences?
No, everything is the same from the middle cross member back. To change a long box to a short box you cut/shorten the frame under the cab.
BigCarl is offline   Reply With Quote
Old 07-06-2009, 05:42 AM   #3
chris71
chris71's Avatar
thanks carl
