07-02-2009, 06:21 PM | #1 |
coil cut???
hey i am just wondering if there is a way for me to cut my front coil with out having to pop my A arm. i am wanting to lower my truck more. so i just thought maby there is an easy way to do it. any way if i cant w/e it dont matter. thanks
07-02-2009, 07:19 PM | #2 |
Re: coil cut???
Yes it can be done.I did a 84 about 10 years ago. We placed a jack on the engine crossmember and jacked it up so both tires were off the ground about 3". Used a torch and cut 2 coils off.Pulled out the 2 coils and let the jack down. This really lowers the front. Had to add alot of shims to get the wheels straight up and down. They leaned way in at the top.
07-02-2009, 08:54 PM | #3 |
Low & Fast!
Re: coil cut???
Just like he said, just cut one coil at a time and test it then if you think it need to go lower just cut 1/2 of the next one.
07-02-2009, 09:09 PM | #4 |
Old Heap Driver
Re: coil cut???
Keep in mind that various trucks have different springs, age of springs, engine combinations that have different weights. My 250 6 cylinder 3 speed truck dropped one inch after i cut exactly one coil, yours may be different. I highly recommend you take out the spring to do any cutting. Sure, it's an all afternoon job, but I see all sorts of red flags trying to torch one while it's installed. That's coming from a guy that has lost 2 friends to burn injuries while they were using torches on a car/truck.
Correction!!! My truck dropped 3 inches with cutting one coil.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. Last edited by S10Fan; 07-03-2009 at 04:49 AM. Reason: Major Typo! |
07-02-2009, 10:02 PM | #5 |
6.0 powered square
Re: coil cut???
that sounds dangerous cutting coils in the truck with a torch and I agree to s-10 fan, I would take the time and take out the coil and cut
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
07-02-2009, 10:16 PM | #6 |
Re: coil cut???
thanks for the advice guys. idk if im gona do it thoigh cuse i all ready have drop spindal's, shackels and one leaf out of each side out. so im just gona wate see how i likethe stance when the motor and the box goes back in then if i still dont like it all take out another leaf and cut the coil and do the job the right way.
thanks agen |
07-02-2009, 10:29 PM | #7 |
yeller
Re: coil cut???
You should NEVER cut a spring with a torch, too much heat, it will affect the spring integrity. Use a cut off wheel for better results. I also suggest removing the spring as opposed to doing it with it in the truck.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
07-02-2009, 10:40 PM | #8 |
the pollock
Re: coil cut???
serioously....rent from autobone a spring compressor.... then do it the "right way" because a accident with a spring can kill you..
period... please dont half ass something like that.. im genuinely concerned for your safety on this one.. plus.. if you have both out of the truck you can double check and grind a "smooth" lip onto it so they sit nicley into the spring cups.. thus preventing unnecessary wear on the parts... or save money and buy shorter springs.....
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
07-03-2009, 01:11 PM | #9 |
Re: coil cut???
ya if i do it i will make it a weekend project and all do it the right way.
07-03-2009, 02:25 PM | #10 |
Robert Olson Transport
Re: coil cut???
with the cheap cost of coil springs why not just buy a set of lowering springs... i mean hey i cold save $30 on jack stands by using a couple of 2X4s but hey... know what i mean?
