Old 07-02-2009, 08:37 PM   #1
1moretoy
need help with 5.3 fuel system
i currently have an rci 16 gal fuel cell mounted between the frame rails and im going to do a 5.3 swap. seeing as money is tight right now and cannot afford a nice fuelcellguy tank, can i use a walbro 255 inline pump for now? if so im going to summit racing tomorrow and will pick one up(that place is awsome). what else do i need if anything. a friend told me these motors have a fuel reg allready. i will post some pics this weekend as soon as i get back home. thanks
1moretoy is offline   Reply With Quote
Old 07-02-2009, 08:58 PM   #2
novafrog
novafrog's Avatar
Re: need help with 5.3 fuel system
as long ,as inlne pumps 65lbs,i used 100 lb pressure,you will need return line,just put 5.3 in nova
novafrog is offline   Reply With Quote
Old 07-02-2009, 09:06 PM   #3
1moretoy
can u explain your set up and what pump did you use
Old 07-02-2009, 10:43 PM   #4
novafrog
novafrog's Avatar
i used a pump from jegs or summit,cost 89.00 i think, only one i could fine reasonable,had to buy sending unit that had return line,you got to have45-60lbs pressure to open injectors,once open you don't need but7 or 8 lbs to run,that where return comes in,if need more call me 304 385 4478 i will try to help
Old 07-03-2009, 07:14 PM   #5
leatherhead63
yes you can. That is what I use in my 72 with a 5.3. Works fine. I have a filter
before the pump and after the pump.
leatherhead63 is offline   Reply With Quote
Old 07-03-2009, 08:54 PM   #6
68 short step
you'll need a constant (atleast) 45lbs of pressure......if its gets below 30lbs of pressure, you'll be able to idle and thats about it.....anything less then 45 you're gonna run into a lean condition...
68 short step is offline   Reply With Quote
Old 07-06-2009, 12:34 PM   #7
tucnnuts
if they can make it so can I!
tucnnuts's Avatar
i think the ls motors run on around 60 psi of pressure...i ran a part#e2000 pump from local autoparts, its a pump used on a ford, inline and i used the ls6 filter it has a return line built in ...comes on new vettes. i only had to run one main line and a short return ...works great..plus if the pump goes bad and can go get one at almost any part store...just my 2 cents
tucnnuts is offline   Reply With Quote
Old 07-06-2009, 07:54 PM   #8
tucnnuts
tucnnuts's Avatar
heres the filter on ebay...http://cgi.ebay.com/ebaymotors/2002-...Q5fAccessories
Old 07-06-2009, 10:27 PM   #9
1moretoy
thank you. do u know who makes the pump?
Old 07-06-2009, 10:35 PM   #10
tucnnuts
tucnnuts's Avatar
depends on which part store you go to ...i think its a part number e2000...its the same pump on like a 89 f150 i think...i know its a ford pump...
Old 07-06-2009, 11:15 PM   #11
boostat4500
I would recommend going with an aftermarket regulator. Will make future tuning and mods much easier. You want to start with about 49-50psi. Then if needed, you can turn up the pressure and re-tune, rather than change injector size, within reason of course.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
