07-03-2009, 02:46 AM | #1 |
Need help on pan hard bar.... Please !!!
Hey fellas i have ran into a little problem with my rear set up. I am in the middle of the process of bagging my 66' swb fleetside. I have a kp step notch with a 4" block under my rear end to fill in the gap. I made my own adjustable pan hard bar longer then stock to compensate for the drop but when i lift the truck up my rear end moves almost 6". I made it long so it wouldn't do that but i don't know if maybe because i used stock mounting location's it's causing to kick over. So, my question here is if i used like a early classic's deluxe track bar that relocates it from on top of the diff. down to the passenger side trailing arm will this prevent so much swing versus it going to the center of the rear end?
07-03-2009, 08:48 AM | #2 |
SSN 706
Re: Need help on pan hard bar.... Please !!!
I'm no expert, but I think the bar has to be centered on the diff. if you want the rear end to stay centered while you move it up and down. You're most likely going to have to fork out $500 for a Watts link. Or a 4 link. I could be wrong. It would be the first time though. Search Watts link .
07-03-2009, 08:59 AM | #3 |
Hollister, CA.
Well, you want the bar to be level at about half travel....but like he said Watts is the ONLY way to go !!
Check out the simple one I built for Richs '67...link in my signature...Not sure what page though...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
07-03-2009, 11:08 AM | #4 | |
Resistance is Futile
Another suggestion is if your ride hite is extremely low, you mite try to raise/fab a new panhard mount higher on your frame. The object being to get the bar close to level at mid-travel, for instance, or ride hite. This would help your issue also. The Watt's will cure your problem for sure.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
07-03-2009, 11:14 AM | #5 |
The longer the bar, the less noticeable the side shift will be on extreme rear suspension travel.
You need a long bar that runs from the drivers side OE frame mount over to the pass side trailing arm. Set it so that the rear housing is centered @ ride height. If you want it centered all the time, go w/a Watts.
07-03-2009, 02:39 PM | #6 |
Right on thanks fellas for all the info. I think i'm gonna end up making a wish bone 3 link set up tho. I can't afford spending $500.00 on a watts sets up right now this is kinda of a budget build fro me, the rest of my money goes to my baby my chopped 54 coupe.
07-03-2009, 04:54 PM | #7 |
SSN 706
Got any pics? Of the wishbone not the baby. I know how you new fathers are. Ok some of the baby would be ok too.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 07-03-2009 at 04:55 PM. |
07-03-2009, 10:10 PM | #8 |
Daring to be Different
Install a triangle 4-link. No need for a pan hard bar, or watts link.
is one is from KP Components About $399 Or this one is from Airbagit.com. It's a little cheaper than KP's
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 07-03-2009 at 10:12 PM. |
07-04-2009, 12:24 AM | #9 |
Member of the longbed union.
With a pan hard your always going to have the axle move from one side to the other. Only way around is to use a Watts link, 4 Link or 3 link using a wishbone!
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
07-05-2009, 12:17 AM | #10 |
I'm adding to this thread for info. If you dont have a Speedway catalog, get one....or visit their site. They do mostly rod stuff, but have tons of things that could be fabbed on and modded to work on our trucks.
How about a simple Watts Link for 70 dollars? SpeedwayMotors.com
07-05-2009, 10:18 AM | #11 |
That's a good price. I order from them all the time.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 07-05-2009 at 10:19 AM. |
07-05-2009, 11:26 AM | #12 |
Thats what I thought, too. Seems like people arent afraid to innovate so you could add some pieces and have a workable solution for some of the suspension issues people get into.
07-05-2009, 12:53 PM | #13 |
Thanks alot guys for this great info. I think i might just have to fork out some chip's and do away with the stock trailing arm set up and just 4 link it.
07-05-2009, 08:58 PM | #14 |
Does this Watts link fit our frames?
07-05-2009, 09:05 PM | #15 |
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
07-05-2009, 09:09 PM | #16 |
It's a generic kit.......catalog says good for frames '46'' or less'. They show it attached to the top of the pumpkin in their illustration, but it would'nt be too hard to make a different mount. See if K/P Components sells their mount seperately?
Just thought it mite get some brainstorming ideas going.....I wouldnt buy a 500 dollar Watts link.
07-05-2009, 09:16 PM | #17 |
I think you guys should use a triangle 4 link. It will end all your problems. Screw that Watts link. I put 20" wheels on a lot of truck, and used the triangle 4 link,s Wheels never rubbed on the sides and still laid frame, plus blew sparks while driving. Keep it simple.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 07-05-2009 at 09:16 PM. |
07-06-2009, 09:07 AM | #18 |
SSN 706
"Screw that Watts link". That's what I like about you Strodder you're just so damn down the earth. I'm thinking that's the way to go. Thanks for the link Trash.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 07-06-2009 at 09:10 AM. |
07-06-2009, 10:20 AM | #19 | |
Keeping it simple is just that: Figure out why there's an issue w/the current set-up. There's a bunch of rides running around w/a PHB that aren't experiencing "almost 6" of movement".
07-06-2009, 10:36 AM | #20 | |
07-09-2009, 10:31 PM | #21 |
Check out this link I found today. http://www.dallashotrodparts.com/watts.html real good price and diffrent styles to look through!
07-09-2009, 10:48 PM | #22 |
Rods
for the time and money just go watts. you can build it or buy a simple version with little fab. and have no problems with future plans
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
07-09-2009, 10:53 PM | #23 |
Hey guys sorry about the link, but i was just told by twistedminis that the company screwed a lot of people and their watts link isn't designed correctly! Check him out if you haven't he's building on now but needs the lenght of the cast on the axle so he knows how long to make the axle link for it!
07-09-2009, 11:00 PM | #24 |
Rods
i made my own for the 31 model a. most of the stuff can be had from jeggs
07-09-2009, 11:01 PM | #25 | |
