07-03-2009, 12:01 PM | #1 |
2000 Silverado 2500hd 4x4 stalling
Just had a wierd situation yesterday when I went to drive my truck. I got to the end of my road to pull out on the highway, and my truck just started to barely run. It eventually stalled after little to no response from the gas peddle. I drove this truck all last weekend. It sat until yesterday. I recently had the throttle body cleaned. I replaced the fuel filter today. I replaced the plugs a couple years ago. I have yet to put new wires or a new fuel pump on it.
Could it be the fuel pump? It will start, but then stall. No codes. Help! This truck has been reliable up until yesterday. |
07-04-2009, 11:47 AM | #2 |
Re: 2000 Silverado 2500hd 4x4 stalling
2000 burb killed the fuel pump and it was 2-300 at the dealer
all we had was a engine light on it the burb would start up but stall your story sounds like mine so id say so how many miles Last edited by redneckwheelman2; 07-05-2009 at 08:57 PM. |
07-04-2009, 12:26 PM | #3 |
easy to find out, put a fuel pressure guage on it. Sound like the pump.
07-04-2009, 07:13 PM | #4 |
07-05-2009, 08:56 PM | #5 |
id say yes the fuel pump went
our burb had 127000 when it went |
07-06-2009, 06:42 AM | #6 |
be sure to use a oem replacement from a dealer i have heard of a lot of problems with the after market ones
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
07-06-2009, 06:29 PM | #7 |
laying low
My nephew told me just yesterday he did some tests on different brands fuel pumps. It's common knowledge that most of the aftermarket pumps do not last as long as the OE ones. His tests showed the non OE pumps basically have to turn 1+1/2 turns to equal the same amount of fuel pumped by the OE pump so they are running more so they don't last as long. Makes sense I guess. Of course the aftermarket pumps don't cost as much as the Delco either.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-08-2009, 01:31 AM | #8 |
Replaced fuel pump tonight. Fixed it. Why did GM make you replace harness end for new pump? stupid
07-08-2009, 10:25 PM | #9 |
laying low
Because over the years there have been many pumps replaced when the problem was the intank harness instead.
Glad to hear you fixed it.
