Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-03-2009, 05:04 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
suspension physics majors???? step up
somone with waaay more knowledge than me please explain why i have been told that traction bars(slappers) are a waste of time on my 81. the rear is still mounted UNDER the leafs as it cam althought the truck is lowered about 5" in the back. I did come up with a way to make traction bars that will mount under the diff and drive up on the front leaf eye.
I just added 4* of negative pinion wedge because i came up with exactly 0* offset while at rest.
I had 4* positive on the pinion and 4* negative on the tranny. My pinion is now 0*. I understand that even the 4*I installed may not be enough. i can't afford any more trial and error. I lost(split) a $1000 trans from this truck on pass #13. thanx , crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 07-03-2009, 05:38 PM   #2
djracer
djracer's Avatar
Re: suspension physics majors???? step up
buy Cal tracs!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-03-2009, 10:18 PM   #3
rookierodbuilder
rookierodbuilder's Avatar
Originally Posted by djracer View Post
buy Cal tracs!
yup, i'm an engineering major, and the caltracs by my knowledge are the best way to go in order to have traction bars that will not bind the suspension
rookierodbuilder is offline   Reply With Quote
Old 07-04-2009, 12:07 PM   #4
crossy
crossy's Avatar
The truck planted fine at the track last night . it's only a 13 sec. truck.
so i havea few more questions for those who chimed in.
What is the safe LOW air pressure that can be run in a BFG drag radial?? i have 275-60-15 on 8" wide wheels.
98 Vortec project.
94,3500,6.5L 4L80
Old 07-05-2009, 08:10 PM   #5
Super73
Super73's Avatar
You can run them pretty low (12psi).. But you should be reading th tire and setting PSI based on that.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-05-2009, 08:30 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Make your own!
My write up.
http://www.geocities.com/abetterchem...ustombars.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 07-06-2009, 04:30 PM   #7
djracer
djracer's Avatar
The M/T drag radials hook hard with 18 to 20 psi.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-06-2009, 04:56 PM   #8
Outlaw72
Hay Team!!
Outlaw72's Avatar
Agree with everyone here....traction bars ARE a waste of time...
Your tires.....I had the MT radial 315x60 and ran them at about 15. That was in cold weather tho.
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 07-06-2009, 09:43 PM   #9
Wild83C10
Wild83C10's Avatar
Traction bars aren't a waste of time, but they aren't as efficient or adjustable as the caltracs. Traction bards will work, but for the money caltracs win. They have a longer arm which helps weight transfer and if you preload them the springs wont move at all.
Look Super73 said, read the tires. You may need to do some experiementing on a back road (I mean track), to see at which PSI you get the biggest tire patch.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 07-06-2009, 09:49 PM   #10
Wild83C10
Wild83C10's Avatar
Originally Posted by gchemist View Post
Interesting writeup. How does it ride. It seems that you have basically locked the leaves from "compressing" or flexing downward. I guess if it's a track only truck then it wouldn't be so bad.
turbo=
Old 07-07-2009, 12:27 AM   #11
AlienYouth
AlienYouth's Avatar
i think ive got my bfg's (325/50/15 on 10") at 10 PSI, they wrinkle up n hook good
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 07-07-2009, 08:22 AM   #12
crossy
crossy's Avatar
G, I thought you moved to Chevytalk only. didn't know you were still here. I remember your thread a few years back on t-bars and thats when people were saying they were not functional because of our spring placcement. I also remember people there was a clearance issue and my truck is LOW. I would still like to see a pic of the caltracs installed. how far in inches are they below the shock mounts or axle tube. thanx , crossy.
98 Vortec project.
94,3500,6.5L 4L80
Old 07-07-2009, 02:28 PM   #13
franks72
Junior Member
franks72's Avatar
Hey Dave, havent run into you in a while. I run 17 psi in my 275s. When are you going to the track again. Im going friday night.
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82
12.39 @111.33 With a 180 shot nos
69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/
email fdelcoglin@hotmail.com
franks72 is offline   Reply With Quote
Old 07-07-2009, 04:58 PM   #14
crossy
crossy's Avatar
wazzup big man:-) , now there are actually 4 whole people on this forum that are a rocks throw from me. Dude you know the deal with me. 18 projects going on. None worth mentioning. I'm a part timer at the track and now i don't want to break anything. I'm scared for the first time to hurt something. I'm prolly going to have a FOR SALE sign in it at the 'BIG SHOW' in Pennsville and i don't want any more shrapnel holes in the floor. I have to work this Thurs/ Friday and going to the shore on saturday for the BBQ competition. THOUGHT about this Wednesday night though. This past Friday was madhouse there. crossy
98 Vortec project.
94,3500,6.5L 4L80
Old 07-08-2009, 08:20 PM   #15
Wild83C10
Wild83C10's Avatar
I will take some measuremets and dig up my pictures. My truck is lowered 6" in the rear. Flip kit, overload leaf removed and a 1-1.5" drop shackle. No clearance issues with the caltracs.
turbo=
Old 07-08-2009, 11:07 PM   #16
crossy
crossy's Avatar
wild, where in Jersey are you located? thanx, for that info. If your truck is low with no clearance issues. they should be good.
98 Vortec project.
94,3500,6.5L 4L80
Old 07-09-2009, 07:27 AM   #17
Wild83C10
Wild83C10's Avatar
I'm in Millstone Township (western Monmouth County) by Great Adventure. If you want to get a better look we could meet up sometime.
Here are some older pictures. I'll get the measurements soon.
Old 07-09-2009, 08:53 PM   #18
Wild83C10
Wild83C10's Avatar
Dimensions were taken with a 25.5" tall tire. The front bracket sits 5" off the ground and the bracket at the axle sits 4.25" from the ground. That is with the overload leaf removed and only 4 springs, if you have extra leaves in there then it might sit lower.
My suspension is slightly different then what you see in the photo above.
turbo=
Old 07-11-2009, 05:53 PM   #19
AirMale
AirMale's Avatar
looks like a good concept: run a soft leaf spring and use the cal-trac to control warp. should've tried that myself.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 07-13-2009, 09:37 PM   #20
85sqbdy
85sqbdy's Avatar
t-bars do work, but only to a certain extent. mine worked fine until i put alot of power to them. the axle twisted anyway and pretty much destroyed the driveshaft and the transmission.
if it ain't broke, fix it until it is.
85sqbdy is offline   Reply With Quote
