Old 07-03-2009, 05:07 PM   #1
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
Carb Help
Bought my truck about 2 months ago,PO was running it with no air cleaner.One of the first things I diid was rebuild the carb.Now when she sits for more than a day or 2 all of the fuel drains back down towards the tank and it is difficult to start.Its a roch 2 barrel on a sb350.Any one have an idea of what might be causing this?Thanks in advance for any input,Mike
1970 Bowtie is offline   Reply With Quote
Old 07-03-2009, 06:12 PM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Carb Help
That's very interesting. I have a Rochester Quadrajet on a 350 and it has been doing exactly the same thing for years. Otherwise it runs perfectly. I would be very interested in hearing what other members have to say about this. P.S. I have a mechanical pump.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 07-03-2009, 10:42 PM   #3
BHyatt
Re: Carb Help
great question
BHyatt is offline   Reply With Quote
Old 07-04-2009, 01:00 AM   #4
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Re: Carb Help
Fuel pump might be bad. There's a check valve in it that's supposed to keep the gas up in the line. If it goes bad the gas can drain out and gradually empty the float bowl. Try a new pump and see what happens.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 07-04-2009, 02:17 AM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Carb Help
that's the same thing I thought when I read this
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 07-04-2009, 08:55 AM   #6
RustyParts
RustyParts's Avatar
Re: Carb Help
Sounds like the notorious fuel well plugs. Check out this link for a fix.
http://www.stratagaz.com/Quadrajet/Q...et_7029202.htm
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 07-04-2009, 09:20 AM   #7
1970 Bowtie
Re: Carb Help
Thanks for the great link RustyParts.Looks like I will be pulling the carb back off and breakin out the old epoxy.Thanks again.
