Old 01-05-2003, 09:16 PM   #1
special70gmc
special70gmc's Avatar
how did all of you lift the cab?
i have the cab all disconnected and was wondering how did all of you lift it off? i there was two ideas i was thinken of jack it up and roll the chassis out of the way. invite 4-5 people overand make em lift it. unskilled labor -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 01-05-2003, 09:24 PM   #2
Dropt72Shortbed
Dropt72Shortbed's Avatar
i did it with a total of 4 guys holding. two of us werent that strong, we almost dropped it. id make sure you have at LEAST 4 strong guys, 5-6 would make a world of difference.
Dropt72Shortbed is offline   Reply With Quote
Old 01-05-2003, 09:29 PM   #3
crazy longhorn
Fabricate till you "puke"
I did mine with people power.......man did it cost me in beer tho....:p 4 guys can easily lift a gutted cab & walk the rails. If you have a cherry picker, you can rig some chains on the floor, & 2 guys can do the job.......more beer for everybody!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-05-2003, 09:30 PM   #4
Estanley
Estanley's Avatar
Four of us picked mine up carried it 5 feet forward and sat it down on a home made dolly. It had all the glass in it, both doors in it, steering column and seat. Wasn't too bad. Oh yeah, about 20 empty beers cans.
Estanley is offline   Reply With Quote
Old 01-05-2003, 09:37 PM   #5
crazy longhorn
Estanley.....you got off easy dude! mine cost me 2 cases of beer........yea the old lady thought we were a little NUTS that day
Old 01-05-2003, 09:39 PM   #6
Dropt72Shortbed
wasnt too bad?! i guess we made the mistake of having to walk it 35 feet off its a frame and up the driveway into my garage, i had to buy lunch.... that sucked
Old 01-05-2003, 09:43 PM   #7
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
If the bed is off the chassis all you have to do is: position jackstands on all four corners of the cab, jack up the cab, place boards across the stands underneath the cab, and roll the chassis out from under the cab. You will have to get it up in the air to clear the tires, but if you don't have a hoist or 5 or 6 guys to help, one or two people could do this pretty easy in about an hour. Let us know how it goes, I'll be doing the same thing in a couple of weeks. Later, ....................JB
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 01-05-2003, 09:45 PM   #8
67cst
i love summertime
67cst's Avatar
me and my dad have moved mine around a lot, it is completely gutted and no doors, since we are using the 85 frame we have had to move it around ont he frame and lift if off and on a couple times, finally got her on though for good
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-05-2003, 09:46 PM   #9
67cst
i love summertime
67cst's Avatar
that doesnt make a lot of sense, i say we have moved it around a lot b/c of the 85 frame due to fabing up cab mounts and rad support mounts
Old 01-05-2003, 09:52 PM   #10
Blue_71
Bloo
Blue_71's Avatar
hook a chain through the cab, hook a come along to the cab and tie it around a "tere pole" in the barn, start cranking the come along
i dont recomend the chain thing though, it bends up the rain gutter thing
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 01-05-2003, 09:59 PM   #11
special70gmc
any one have plans for a cab dolly i could make from 2by 4's would you ?
1958 belair 2door
Old 01-05-2003, 10:52 PM   #12
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Check XXL's site, he's got one there, I don't think he'd mind
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 01-05-2003, 11:04 PM   #13
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
XXL has a plan for a dolley. our car hoist had the drag car on it when I pulled mine. mine has everythig in it still to, got out the loader tracker, bought two 20' by 3" straps, wrapednder an forked it. works real slick just make sureyou got steady diver
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 01-05-2003, 11:06 PM   #14
Kman
cab
I used an engine hoist, connected straps tightly at 4 points inside cab with doors off and seat out, through door latch and down around front of cab hooked it in the middle and pumped it up just have to balance it right only took two of us then rolled the hoist away and put the cab on a dolly no sweat
Kman
New 89 chevy 1500 driver
72K20 rust bucket project stripped down to the frame engine rebuild started
71 Blazer - another procect
Kman is offline   Reply With Quote
Old 01-05-2003, 11:10 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The way Fine69 has it looked pretty god I think.
A long 4X4 beam with chains on both ends, stick the beam through the cab and lift it with a hoist/comealong. No damage to my cab, no beer, no sore backs.
Old 01-06-2003, 11:16 AM   #16
Estanley
Estanley's Avatar
Maybe a little late but here's a pic of my dolly.
Old 01-06-2003, 11:17 AM   #17
Estanley
Estanley's Avatar
Don't know what happened to the pic????
Old 01-06-2003, 11:52 AM   #18
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I lift cabs with my engine hoist. I take an 10' 4"X4" and tie it down to the top of the engine hoist. Tie it down so that enough 4x4 runs past the end of the lifting arm to stick past the door opening oppisit the side you will be lifting from. Possition the hoist so that the top of the 4x4 is directly under the verry top front of the door opening. Jack the hoist up untill the 4x4 touches the underside of the door opening oppisit that you are lifting from. Then proceed slowly untill the 4x4 is touching the underside of the door opening on the side you are lifting from. The I drive a couple of nails into the top of the 4x4 to keep the cab from sliding toward you when you lift it and lift away. Works great and I can even load cabs into the back of other pick up trucks using this method. Good luck and this way is a one man operation so you can drink all the beer yourself.... WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-06-2003, 04:42 PM   #19
special70gmc
thanks guys, im probly gonna build one like estanly's since its snowing right now i cant do much else.
1958 belair 2door
Old 01-06-2003, 05:07 PM   #20
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's the one man approach I just did. Seemed to work pretty well. I put a small two by four under the rain gutter, that kept the strap off the gutter so it wouldn't bend. I used two straps through the cab and then one around the outside of the cab running down the middle of the cab.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-06-2003, 05:11 PM   #21
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's the front view.
