Old 07-03-2009, 06:51 PM   #1
1981C10LWB
1981C10LWB's Avatar
Dual Electric Fan Wiring Kit
I have a dual electric fan off of a 97 3.8l Camaro. They are almost identical to the lt1/ls1 fans. I was looking at the wiring kits and noticed that there are different ones for single and dual fans. Which one do you recomend for dual fans without spending a fortune? Also should I set it up so that both fans come on at once? Thread in sensor or radiator probe?
BTW, I read here that both the fans combined pull 57 amps on start-up and 13.6 amps afterwards. Didn't know if that would influence what kit was needed. I would just use the one in the article but the price is kinda higher than I was looking to spend.
1981 C10 LWB – 350/TH350 – Work In Progress – 1st Vehicle
1981C10LWB is offline   Reply With Quote
Old 07-04-2009, 11:03 AM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Dual Electric Fan Wiring Kit
Anyone?
tvblazer78 is offline   Reply With Quote
Old 07-04-2009, 01:30 PM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
past me on this one..
ask vette.. he might know.. or request a move to the electrical section specifically you will get a good response there
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-04-2009, 04:08 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Wire each fan with seperate relays. The only common connections shoud be two. One IGN source to each relay. Tie the relay inputs (on) together down to the head probe. Use a fuse between the battery and the relay. I use the 30 amps fuses. The fuses have two little nuts on them.
The head probe replaces the adjustable theremostat. The high and low side to each fan. Tie the 85 connections together. You can ground them any way you like.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
