07-03-2009, 07:00 PM | #1 |
Gas Gauge problems-
I'm still having problems with my Gas Gauge, I have read most of the other treads but still need to know my next steps. Here's what I've done:
New sending unit, New gauge from LMC, New wire from fuse box to sending unit on top of tank, Gauge seems to work, I'm getting a empty reading with key on, I took the wire off of both ends (Fuse block and Tank) both times the reading goes to full (3:00), Is the tank grounding itself at the top or is this OK? I can take the wire off and touch the sending plate and the reading will go back to empty, is this OK? TJ |
07-03-2009, 07:55 PM | #2 | |
Re: Gas Gauge problems-
69 Chevy 4x4 383 Power |
07-03-2009, 09:09 PM | #3 |
I think that is the proper way to test it. Mine was not working at first after passing the tests you did. I then took the sending unit out of the tank and made sure the gauge would move when I moved the float up and down, and it did indeed work fine. I then noticed that the float was very close to the filter that is on the pickup line and it was getting hung up and not allowing it read past empty. I bent the line the float is on over a little and it worked great after that.
07-04-2009, 08:21 AM | #4 |
I'm going yo take the sending unit back out and give it another try, will test the float like you said.
TJ |
07-04-2009, 10:00 AM | #5 |
Hawkwer7 is correct, I took out the sending unit, moved the float over a bit , did the testing to see if the gauge moved with the float, it did, replace the sending unit, it nows shows about 1/2 tank and stay there's with the key off. Is this correct, does the gauge read correct this way at the fuel level or does it suppose to go to empty with the key off?
TJ Last edited by tjvending; 07-04-2009 at 10:01 AM. |
07-04-2009, 11:00 AM | #6 |
its all about the +6 inches
some of them will drift a little, but for the best part, they stay put.
07-05-2009, 08:26 PM | #7 |
I tought I had it fixed, It seem to be working with a half of tank (10Gal I put in a few days ago) I went to the gas station and put another 7 gal in and now the gauge is marked way pass full, at the 3 o'clok position, now what, should I pull out the sending unit again?
07-05-2009, 09:32 PM | #8 | |
The Older Generation
LockDoc
07-06-2009, 11:51 AM | #9 |
Where would the ground wire on the cluster be coming from, I see the main wiring hraness but no other loose wire, except for the shift indicator?
07-06-2009, 02:19 PM | #10 |
Msgt USAF Ret
A 3:00 reading usually means that the gauge has lost it's grounding connection back through the sending unit to tank, to frame. Did you remember to plug the tan wire back into the fuse panel that goes to the sending unit?
Here's a neat little diagram to show how it all works.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-06-2009, 11:00 PM | #11 | |
I hope this is as clear as mud... LockDoc
07-07-2009, 08:46 AM | #12 |
I had a heck of a time getting mine fixed, symptoms were the gauge would stay at 1/4 tank no matter what I did. Replaced sending unit, same symptom.
I read every post I could find here in the forum and discovered there is one more component involved, the gas gauge resistor. The sending unit should read from 0-90 ohms if you place a meter on it, the resistor on back of the gauge should ohm out at 90 ohms also (after you take it out of the cluster)...I have a stock 72. When I replaced my resistor the gauge would go way past full when testing with the sending unit out. I reversed the resistor and everything started working fine. Something tells me there is more to that resistor than meets the eye. Hope this helps. |
